Extremely Poor Headlight
Recommended Posts
I guess a newer central electrics module might let you use fogs for ch/lh but could be a minefield.
I use ch/lh with my factory xenons and on a 6.5 year old car with 127.5k miles have never had a bulb blow.
Link to comment
Share on other sites
Yes definitely. I spoke to the chap at Londoncolour about a year ago, perhaps longer, and he was telling me to get  a canbus friendly kit. I told him I was getting the non canbus and I was having the HID kit coded in. He said that's fine then. I'd read all the threads on here carefully, and knew that it was bad advice to buy a canbus friendly kit. I bought the non-canbus kit, had the coding done and that's the way to go! To be fair to Londoncolour he only sells the kits, he's not going to know the details of what to put in every model of car.
Link to comment
Also it sounded right in my mind anyway, I know the damage capacitive and inductive loads can do to delicate electronics, sticking a large capacitor across the load to fool the controller that its a filament bulb isn't a clever solution really.
Link to comment
Exactly as Phil says. The only option for using fogs with CH/LH lights is provided on preFL with factory xenons. Mike
Mike
Just seen this. Have you done this on a pre FL as I couldn't find this in the coding and I have factory fit Xenons. Maybe it needs the 30 byte cecm? I would prefer to protect the Xenons but want to keep CH/LH so it is of interest to me.
Ta
Adam
Link to comment
The slimline ballasts fit inside the headlight casing.  Just use double sided foam pads or self adhesive velcro to secure them to the bottom of the unit.  In fairness, once the ballasts and igniters are in there, along with the wiring, there isn't lot of room for them to move anyway.  It's a really neat job with everything enclosed within the headlight itself. Mike
Cheers mike :)
Link to comment
OK, further to a PM from Cleo, he has told me that he has emailed london colour and that they are telling him that he needs the canbus friendly kit. Once again, and I've lost count of how many times I've told him now :wall:  :wall:  :wall:
Mike
Ok ok ffs I hear you
Link to comment
I went through this process a few months ago as the Skoda Octavia vRS has the feeblest dip beams of any car I've driven in 40yrs. I can't repeat my actual words here!!
This is a bit confusing at first but after reading all the posts here on HIDs/Xenons I was convinced I needed the London colour Non Canbus ones and to get coding done. All good now.
Fitted all parts inside the headlamp unit using Halfords self adhesive velcro to secure. Coded by a member here thankyou.
It's a no brainer for £25.00. Eight years ago I fitted HIDS to my Subaru Impreza, which also had poor lights for a 320BHP car. Did high and low beams, wow the high beam was fantastic No problem passing MOT every year, not even a question asked. Never got flashed by other drivers as had manual beam height adjustment so kept low in traffic.
Would love to do the high beams on the vRS but seems it's not possible with the coding etc.
Has anyone changed the 35w for the 55w HIDs as I'm curious on the improvement.
BTW you can remove the headlamps from the car quite easily, take them indoors fit all the bits and then refit to car, then get it coded.
Link to comment
I have noticed that the London Colour HID kit takes much longer to reach full temperature / brightness than the factory fit OEM xenon headlights.
On our Octavia with factory xenon's the lights are bright enough to see as soon as you flick the switch with only a very small amount of warming up evident, say a second or so.
My HID kit has the flash as mentioned above but then the light all but disappears (at least from behind the wheel). Over the course of about 5 to 10 seconds they reach full brightness.
Whilst warming up they are very blue and eventually become whiter.
Not a major issue but one of the biggest differences I've noticed between the £30 HID kit and the close to £1,000 factory fit option.
I think I'd sooner wait 8 or 9 seconds before driving off and save the £970 difference
  • Like 1
Link to comment
I wasn't complaining, just my observation versus OEM.
There must be a difference between the two systems that allows one kit to warm up (or reach full brightness) quicker than another...
Link to comment
Hid's all coded with cornering lamps activated and led number plate bulbs activated.
Did have an issue with the Drl's not working but that was due to the bi-xenon with shuttering activated by mistake.
Thanks to R K ENGINEERING in St Agnes for coding and thanks for the advise on here.
Must get my self VCDS!
Link to comment
I can certainly second the really poor light output of mine too (octy mk2) they're the worst I've had in a car yet, it's bordering on dangerous on unlit rds I don't know. They're aimed right too as I got it done the other day, only the drivers was down a bit, and not by much at all. I've only got ordinary 55w halogens in but very tempted to put hid in as its got projectors anyway
Link to comment
Do headlights have a wide variance in output power? I only ask as there are many people that are dissatisfied with the lights on the mk2 and yet mine seem to work well and are nowhere near 'dangerous' or even 'bordering on' when driving along unlit roads as Cleo seems to suggest.
I can understand the output degrading as the bulbs age or if the reflectors/lens start to cloud or discolour but other than those factors I'd expect them to be pretty similar when correctly aimed and cleaned.
Link to comment
... mine seem to work well and are nowhere near 'dangerous' or even 'bordering on' when driving along unlit roads ...
Me likewise.  No problem whatever, and I live out in the sticks.  I wonder why some people have a problem?  Why should some cars' lights deteriorate, and not others?
Link to comment
I'm hopefully going to someone local at the weekend for a vcds scan maybe they'll be able to tell me why, it'll be dark when I'm there and will gladly suggest if he wants to take it out as there's plenty of dark rds near him
Link to comment
I think a few members have reported that the reflectors inside the projector headlights can deteriorate over time.
I'm guessing this will be influenced by the age of the car, the climate and how often the headlights are used etc.
It seems plausible then that some members may experience different light outputs on different MkII Octavia's?
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
