Oil change
G1ZYX
Recommended Posts
Hi all,
Had my Fabia  1.2 htp converted to gas from new 63 plate.
My question ,a little tricky- The oil change has displayed on the dash after 1 year and 4000 miles BUT I am on LPG gas and the oil should be much cleaner, and it is, plus I do not do short journeys, 20 miles each time I run it.
Should I change it, as the warranty may be effected if I don't . I do not want to waste £70 on a oil change for the sake of it.
Link to comment
Share on other sites
Welcome to the Forum.    (Maybe your Post will get moved to the Skoda Fabia 2 Section.)
Do you mean the Original Manufactures warranty with Skoda?
Is the PLG Modification approved and keeping the OMW valid?
 Was it done by a Skoda Dealership, or Factory Fitted?
Is your car on Fixed Servicing and 9,400 miles /372 days,  Could it not have been on Variable Servicing.?
If you car is on Fixed Servicing you need to follow the Service Schedule / Guidelines to keep a OMW Valid,
so Serviced & Oil Change.
You need to Talk to Skoda Customer Services & then get in writing what they say on your Warranty being Valid.
Your first service including Oil & Filter change should not work out as being £70 for the Oil / Filter & Sump Plug.
george
PS.
I would consider 20 miles each time as short journeys.
I have run V8's on LPG without Petrol Start up, and the Oil stayed Golden,
I still changed it regularly though.
Edited by goneoffSKi
Link to comment
As I've previously posted, one of my hobbyhorses is to change oil & filter EVERY YEAR or sooner if high mileage.
It's not expensive and many can do-it-themselves thus saving money.
Low mileage/short journeys are less good for engines than longer journeys so just change the oil to be sure. It can't do harm and, in my opinion, positively helps engine life.
  • Like 1
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
