General Car/Service Questions 2006 Ambiente 1.6
Recommended Posts
I like to disconnect the battery so I can clean the corrosion however in the manual it statess battery can be only disconnected when the ignition is on :think: . Isn't this dangerous or is the manual right?
Link to comment
Share on other sites
If you have the user guide/manual then sometimes there is a sticker with all the option codes in that.  (not in mine though).
Failing that, adjacent to the spare wheel well.  Mine is quite hard to read now, so maybe a photograph which you can enlarge on your computer.
Link to comment
It's a misprint, and a very stupid one. Later editions of the manual were corrected to say 'off' rather than 'on' .
Ok what else is misprinted in the manual so I know what to look out for upon reading it.
Link to comment
We have a 64Ah battery, "Exide premium EA640" It came from a local battery specialist, where you just give them you reg number and they fit the right battery for you.
Yeah that's the battery I just bought today. Thanks,
Link to comment
Hi does anybody know for the above?
Also in the manual it states I can get into the main menu of the dashboard by pressing the rocker switch for more than 1 second however I cant seem to get into it. Please advise.
Link to comment
Does the car have a Built-in On-board Diagnostics system that lets the driver run tests of the whole electrical system of the car? If yes how do I activate it?
You need VCDS...
http://www.ross-tech.com/products.html
http://www.briskoda.net/forums/forum/23-diagnostics-vcds/
Link to comment
Also how do I take off the engine cover?
Any pics of these would be really helpful.
It is in the link I posted back at post #18.
Undo a few clips and pull in each corner where the lugs are (highlighted in blue)...
http://www.s****monkey.com/vw/jetta/2006/remove_engine_cover/
Edited by silver1011
  • Like 1
Link to comment
Do you have Maxidot? This is the only driver-based menu...
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
