Issues with Yeti wing mirors
Skoda4x4man
Recommended Posts
My friend has a 2013 Yeti
If she adjusts the passenger side mirror - all is well
If she tries to adjust the drivers side mirror - both mirrors move
her local dealership say its a well known issue but, don't seem to want to fix it
Any ideas ?
Chris
Link to comment
Share on other sites
If you have a radio which also has the car settings there is a setting for mirrors, you can tick/untick a box so only the side you wish to adjust alters, the same can be done with a VCDS ( I think )  It's not a fault, it's a setting. Think the idea is so you can lower/raise both mirrors at the same time whilst reversing so you can see the curb
Maxidot might work ( if fitted )
  • Like 1
Link to comment
It can be changed in Maxidot (if fitted) or with VCDS.
It just proves how little your dealer knows (or is prepared to help you with) as it is not a 'design fat' but an actual feature documented in the manual; synchronised mirror adjust (or very similar).
Link to comment
Is this not an option on the Maxidot?
From the manual.
Synchronous adjustment of the mirror
› Activate the synchronous adjustment of the mirror above the MAXI DOT display
in the menu item Mirror adjust. » page 47, Settings.
› Turn the knob for the mirror control to the position for the driver mirror adjustment.
› Adjust the mirror to the desired position.
Link to comment
From the manual
Link to comment
From the manual.
Why would that be an option?
Link to comment
Because once you have adjusted for your stance and maximised rear vision for your driving preference you can easily adjust should you vary seat height or want to do some tricky reverse parking and change both mirrors temporarily.
Link to comment
Imagine the issues the senior tech in a multi franchise dealership has - having to know every option available on every model of every brand since 1s and 0s have taken over our lives.
Well he wouldn't have much dirt under his nails.
Link to comment
Jack of all trades aster of none rings true there.
The dealers and those that fault find should know what the cars should be capable of.
Link to comment
VAG cars have all had this "option" for many years now (to set ONE mirror and the other one follows - which means you have to set ONLY the driver's mirror)...  if a dealer doesn't know about this he also probably thinks VW still sells cars with engines in the back and ten to one he doesn't know the wheel has been invented either.
Edited by 900000
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
