Stage 2 remap what clutch?
Recommended Posts
Hi all
Just got my stage to up an running from shark performance an woooooooooooooo what a difference its like having a brand new car :-) money well spent.
Question I have is has anyone on here got stage 2 an what clutch are you using??? I have standard clutch an it's only 6 months old but I've got a slight slip in 5th gear im not surprised seeing as how much power I have now but just wanna here what clutch is best to go for where to buy an parts numbers if possible
Daniel
Link to comment
Share on other sites
G60 single mass flywheel and VR6 clutch kit. OEM from TPS. Ohh and if not already got one get a diff !
^^ What he said!
Though once I got the hybrid fitted and tuned and started making 295lb/ft of torque the VR6 clutch started slipping. Had to take it to a specialist and get it strengthened.
Link to comment
What diff?
Just posted this in another thread:
I have a Wavetrac LSD in my Octy. It's an excellent upgrade from stock. Not cheap once fitting is factored in as well, but it changes the way the car accelerates and corners. It now pulls around corners in a way it never did, doesn't have that bogging down understeery feeling exiting roundabouts. Grip is so much better. I'm running about 265bhp and 300lbft and no longer have traction issues off the line, unless I drive like a complete tool or it's so wet that both wheels spin. Plus I tried flooring it from standstill with one wheel on gravel, and it just went, no slipping.
LSDs are awesome!
  • Like 1
Link to comment
I've had the stage 2 set-up (228bhp at midland VW) on the car for 12 months and stage 1 for the previous 4 years, I'm still running the standard clutch that was fitted at the Skoda factory in 2003 and 133000 miles ago.
She gets driven "enthusiastically" from time to time and is used for my commute to work and back, also used to tow an 18ft car trailer with my rally car on top with no problem.
Link to comment
Towing Capacity for Skoda OCTAVIA 1.8 T RS
Year Kerbweight (Kg) 85% (Kg) Towing Capacity (Kg) Towing Capacity (Lbs)
2006 1280 1088 1200 2645
2008 1280 1088 1200 2645
This info was taken from UK Tow website and as such I can't be held responsible for any inaccuracies.
My advice if you want to Tow stuff get a Range Rover.
Edited by group1rs
  • Like 2
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
