Fabia VRS aerial lead, changing to dab
Recommended Posts
Hi guys
Goignt o be removing my aerial mast and base and installing a new dab/fm aerial.
Amplified will not be needed so will be running new cables all way from aerial to head unit.
Anyone done this? Got a guide? tips?
Where does the previous cable run please? Maybe I can disconnect both ends and tie string to one and pull it through?
Matt
Link to comment
Share on other sites
I just have a screen mounted DAB because i was planning on smoothing the roof - but im tempted to do a roof DAB to stop there being the occasional drop outs.
As for pulling it through, i would imagine itd be up the A pillar?
Link to comment
I don't fancy your chances of pulling it through. I extracted the cable from my dead Felicia recently and it went round some very tight corners and snagged on lots of bits even when I removed the cladding from the roof and pillar and helped it along.
Why can't you use the same cable?
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
