1.2 12v Fabia, won't start
Recommended Posts
Got a 2003 Fabia, 82,000 on the clock, but it's a none runner... Just had a quick look at it.
No fault codes
Got fuel pressure and plenty of petrol
Got a great spark
Compression test shows...
Cylinder 1 - 180
Cylinder 2 - 190
Cylinder 3 - 155
So compression is down on 3 but 155 should still be enough to run shouldn't it?
I'm thinking the timing chain may have failed and jumped a tooth possibly?
It has full dealer service history also.
Link to comment
Share on other sites
Get it to cylinder 1 TDC. Undo the covers off the ends of the camshafts. Eyeball the slots. Should both be horizontal, in a straight line with each other if all is well chain wise.
Can find some pics later.
Link to comment
Was my next step but it's outside and snowing heavily! I've got a bad back so limited in what I can do, might have a look tomorrow if it's any better.
Also, this won't show any failure between the bottom and top end, only if each can has moved slightly. Any timing marks to line up by eye?
Dodgy valves on these ones
It's possible on number 3 but 155 should still be enough for the car to run
Link to comment
Yeah it will. If the bottom end is one tooth out relative to the top end (but the two cams are OK relative to each other) the slots on the cams will be away from horizontal when Piston No.1 is at the top of its travel, and not lined up with each other.
When I say horizontal, I mean perpendicular to the tall axis of the engine, as the whole engine sits tilted forward or back a bit, I forget which.
If all is well, at No1 TDC  you should see =   =
If all is not well, it'll be more like /  /  or \  \ (but not as steep angles as those)
Edited by Wino
Link to comment
Good diagram haha thanks.
I've done many Vauxhall timing chains and others including two of these engines so understand what you mean about lining them up.
I have a timing kit but it's a pain putting the crank one in for now, just doing simple things to eliminate :)
Link to comment
No.1 Sparkplug out,  long thing down the hole onto the piston crown, turn engine until it's highest, that'll get you close enough. No need to lock for this check. (Much, much easier to turn engine with all three plugs out, as I'm sure you're aware). Doesn't matter if it's TDC on compression stroke or exhaust stroke either, the cam slots are horizontal in both cases.
Photos in this post.
Edited by Wino
  • Like 1
Link to comment
And to clarify, if anyone knows.
Is the main fault with these the valves just getting dirty and not seating properly?
Would removing the cylinder head, cleaning all the valves and reseating them fix the problem?
fairly sure this is Taylor 93s subject
  • Like 1
Link to comment
According to the self-study programme on the 3-pots it takes death of crank and cam sensors to prevent engine start. I quote:
Substitute functions
Engine speed sender G28, camshaft position
sender G163
If the engine speed sender G28 fails when the
engine is running, the engine stops. It can,
however, be started again.
If the camshaft position sender G163 fails
when the engine is running, the engine
continues running and can also be re-started.
If both senders fail, the engine cuts out and
can no longer be started.
On the subject of valve issues, I've read various things but have no hands-on experience of any.  Poorly installed valve seats was one thing I saw mentioned somewhere, but that may have been an isolated incident.
Worn valve guides (particularly ex.) leading to valve stem wobble, causing mis-seating valves and subsequent hotspots/burnout/cracking seems to be more often written.
Doubt you'll be as lucky as to find just 'muckiness' as the cause of lower compression on pot 3, but I could be wrong.
Edited by Wino
Link to comment
I just think something is stopping it from starting other than the slightly lower compression on cylinder 3. I only turned the engine over a few times and didn't touch the accelerator pedal. I think if I continued to turn the engine over and fully pressed the throttle it would raise again.
I feel with the compression results I've got it should start and run, anything over 150 is acceptable to me. It's got fuel, it's got compression and its got spark, it should run...
Link to comment
Agreed.
Did the ECU handshake, if so can't you check measuring blocks for stats like ignition advance, coolant temperature, injector duration etc. while you crank it?
Link to comment
Yeah, I can check all the live data tomorrow also I guess. I'm just going on the assumption that if love data had a fault it would have logged something by now.
Tempted to tow it down the road to jump start it to or at least log a fault code.
More time needs spent on it anyway, only had a quick look over it today, just posted to see what other people think.
Link to comment
Yeah, looks that way, happy in a way, just unsure what to do next. I bought it expecting to replace valves and do a timing chain at the same time anyway, but now I'm thinking maybe just leave the cylinder head and just replace the chain...
But then it's a worry being a common fault to wear out valves and dirt seats etc, and of course if the valves have touched the piston but I think that's unlikely.
Edited by hutchysrs50
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
