1.2 12v Fabia, won't start
Recommended Posts
Contrary to what Toxic said, i dont know why these engines burn up exhaust valves, probably as Wino said, poor valve guides/valve seats at the manufacturing state.
I have heard of people not topping up the oil, which has resulted in chains stretching/premature wear on the valve train, I am under the impression that the 1.2 12v's do have oil pressure controlled chain tensioners. So it only takes someone to mistreat the engine and they seem to go pop!
Regarding Compression, with the Oil at atleast 30 degrees Celsius
at new:          15 Bar
wear Limit :   11 Bar
Max diff :         3 Bar
if you are reseating the valves, both intake/exhaust valves have a 45 degree valve seat.
hope this helps
  • Like 1
Link to comment
Share on other sites
So cylinder 3 is past the wear limit regardless then!
Is there a way to just remove the "rocker cover" and line up the timing to check it runs or is that not possible on these? Ie a full strip down is needed.
As for the valves, I was going to replace the exhaust valves and just clean up the inlet valves if they are ok, will be grinding them in by hand (well a tool you put in a drill) and the paste so the angle shouldn't be a problem would it?
Thanks.
Edited by hutchysrs50
Link to comment
I reckon it would be worth trying to get it indoors, and a bit warmer, charge the battery fully, then repeat the compression testing.  It might be wishful thinking, but could it be that you did the logical sequence cylinder 1 first, then 2, then 3, and the battery was tiring by the time you tested No.3? I'm not sure that speed of cranking should really affect the compression reading much, but it must do to some extent.
Link to comment
For my own piece of mind, I think I'm going to take the head off, at least I don't have to worry about it at a later date. For the price of some valves and a head gasket set its worth doing when the timing chains off, since it's abit of a chew just changing the chain.
Link to comment
Agreed, you'll need new headbolts as well.
Link to comment
If the valves are gone (judging by the reading you have from the compression test it is likely gone) Then replace all of them with the guides. Car will start with the iffy valve but run on one less cylinder, which is super fun when you're 80 miles away from home and haven't a clue when you are. Hope you get it running!
Link to comment
I've never changed a valve guide, so don't think I'll be replacing them. I will however check for play in the valve and if it does need replacing get an engineer that does them for me usually.
It's just an extra cost for a cheap run around, don't want to go over £150 - £200 ideally.
Link to comment
I had all three valves and guides replaced with a new head gasket + all stuff needed for that for £250 (I didn't pay it, my dealer had too as car was sold to me broken) Can't complain!
When the car does fire up, it'll shut down the cylinder pretty quickly, mine was when it idled hot so i got a misfire code.
Link to comment
Got round to pricing up parts today.
Timing chain kit - £115
Chain, guides, tensioner, sprockets, proper sealant, crank seal and bolts.
Head gasket set - £46
Head gasket, valve stem oil seals, head bolts, exhaust gasket and 5 o rings for coolant and inlet.
Exhaust valves (6) - £40
So a tad over £200 for everything needed to do the full job.
Will have to check valve guides but really hope they are ok or will at least be better with new valves in. Will also give the cylinder head a very light lick over so it's totally clean and flush.
  • Like 1
Link to comment
Good luck with it.  :)
Does Haynes (or Autodata, or wherever) have a figure for maximum acceptable valve-in-guide front-to-back waggle?  Can't remember whether I've seen reference to checking them.
Link to comment
I've got a manual so will check, if it's bad then it will have to be done, but slight play I can live with. Hopefully the new valve will be slightly thicker and take up a tiny bit of the play. At the end of the day if it runs fine now, then it will run fine with some new valves and the others taken out, cleaned and ground in some extra also.
Link to comment
Also, any advice on removing the side cover?
All the vauxhalls I've done in the past have handy raised lips at the side so it prises off no problem, I've done two fabias now but a few year ago and can't really remember how I got it off.
Link to comment
Wear limit is 0.55mm for exhaust and 0.50mm for inlet.
As for advice for removing the side cover it says..
"Removethetiminggearcover.Useslightknockswith a rubber-headed hammer from outside to loosen the cover as necessary (the timing gear cover sits on the fitting sleeves)"
Although it still seems pretty solid!
Link to comment
Well done finding the wear limits, I didn't find that in Haynes yesterday.
What it does suggest when taking the chain cover off is taking the sump right off first, which then gives you a bottom edge (of the chain cover) to grab and pull, I guess. Never done it though, so maybe no help?
Link to comment
Nylon hammer, give it some.
20 thou on the guides means the valves will rattle from side to side with no springs fitted.
Edited by sepulchrave
Link to comment
Thanks, might get to try next week depending on the weather.
The sump is still on currently, removed half the bolts from it though, it will need to stay in place until the day the job gets done so the bonnet can still get closed. When I fit the engine support the Bonnet will be left open until the jobs pretty much finished.
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
