wider tyres on the back, why would you?
Recommended Posts
I saw an add for some cheap alloys that I though might do as winter rims so I asked the seller about them and about the tyres they come with.  No answer yet on rim width and offset but the tyres are:
Front 225/40/18
Rear 235/40/18
Why?  Just why?__I'm probably being a middle aged grump and jumping to conclusions but I'm now picturing the seller as a young boy racer that tricked his car out and put the wider tyres on for looks.... Not that you would notice!
His car is (or perhaps 'was') a golf. No idea on exact type.  OK if its an R or GTI maybe wider tyres for dry grip but wouldn't you do all 4? Just the rear would do f*** all surely?!
I'm only after the rims really but if I get them... What to do with a pair of 235/40/18 tyres? Fit to the front in the summer and wear out, or eBay?
I'm a puzzled grump!
Link to comment
Share on other sites
Doesn't that make the rear 'wheel' larger as well?
The quoted sizes will have a larger circumference at the rear yes.
BMW reduce the profile % to compensate for this.
Obviously the guy is a spoon, I'd just put the tyres on one of the local relevant Facebook selling pages for £20 and be done with them.
Link to comment
Front 225/40/18
Rear 235/40/18
Sell them to a VW EOS owner. (Std. tyre size if the car has the 18" wheel option.)
Link to comment
Yes the rear size is taller by 40% of the extra 10 mm of width, you wouldn't notice that.
Yes well, if the seller responds with the info I need ( rim width and offset)_and I buy the rims, I think those tyres will be sold on cheaply.
Link to comment
Front 225/40/18
Rear 235/40/18
Square setup seems to be the norm with most cars FWD cars, however a non-sq set up is favoured on RWD cars, BMW is a good example of this.
The tyre sizes detailed above are wrong for a perfect match.
              225/40  v 235/40
Diameter 637.2mm v 645.2mm
Circumference 2001.8mm v 2027mm
Poke 42.6mm v 32.6mm
Inset 122.6mm v 132.6mm
Speedo error 0% v -1.24%
Reading at 30mph  30mph v 29.63mph
Reading at 60mph 60mph v 59.26mph
Ride height gain 0mm v 4mm
Arch gap loss 0mm v 4mm
Lets just say you wanted non sq set up, 225/40/18 upfront and 255/35/18 would be the perfect match.. (but then you need to check the rim width, clearance etc.. )
ie - Front 225/40 v Rear 155/30
Diameter 637.2mm v 635.7mm
Circumference 2001.8mm v 1997.1mm
Speedo error 0% v 0.24%
Reading at 30mph 30mph v 30.07mph
Reading at 60mph 60mph v 60.14mph
Ride height gain 0mm v -0.75mm
Arch gap loss 0mm v -0.75mm
Not sure how ABS sensors, TPS etc work and tollerance but if the rolling circumfrance differs you could get issues with error
Edited by RickTT
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
