VW Passat R-Line Instrument cluster to Octavia Mk1 ?
kamilrcz
Recommended Posts
Octavia mk1 has blue and green connector. But New R-line cluster have only 1 connector, I will try to find functions.
http://workshop-manuals.com/skoda/octavia-mk1/electrical_system/electrical_system/instruments_gci/dash_panel_insert_(?_my_00)/contact_assignment_of_plug_connections_on_the_dash_panel_insert/
There are two connectors on the back of the panel called T32 (blue) and T32a (green).
Blue T32
1. Connection KL 15+
2. Control light for the right turn signal
3. Output signal of the electronic speedometer
4. Free
5. Fuel gauge
6. Airbag
7. Connection KL 31, sender earth
8. Coolant gauge
9. Connection KL 31 earth
10. Oil pressure switch
11. KL TD, revs signal
12. KL 61, control light for the generator
13. Diesel preheating system
14. Control for the foglights
15. Free
16. Signal for open boot
17. KL 56A low beam control
18. Control light for the left turn signal
19. ABS System
20. KL 58D, illumination of the instrument panel
21. Signal for open driver door
22. Coolant level warning
23. KL 30, clock
24. KL 31, earth
25. Line K, self-diagnosis
26. Right parking light
27. Left parking light
28. Electronic speedometer input signal
29. Brake wear control
30. Contact S
31. Seat belt
32. Engine check control
Green T32a
3. Control light for parking light
10. Fuel reserve warning
15. EPC
The connections not mentioned are assumed to be free.
Link to comment
Share on other sites
The problem is that the Passat cluster is all Canbus data, whereas the MK1 octavia had no Canbus at all.
Please what about VR6 2.8 24V 150kw VW Sharan 2002, he have canbus data or no ? I am going to swap ... Thank you in advance.
Edited by kamilrcz
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
