Reset "Inspection Now" warning
Recommended Posts
Hi all :)
I have a Skoda Rapid 1,4 Tsi.
Yesterday I went to do the inspection for the 30,000 Km. Now every time I start  the car and close the door, a warning that says "Inspection Now" displays.
I tried to reset this by pressing the button on the dashboard and turning on the car. When i do this I get a message saying "Are you sure you want to reset" I press ok . Everything seems ok until I turn the car on again...And the warning comes back
Any suggestions? Thanks a lot!
Link to comment
Share on other sites
I think Juan123's issue is different and I think, if I understood it well, it happened to me too. So, after the first revision, the notification for revision continued. I contacted the official garage and they said it is normal until the car performs more 1000 KM (if I am not mistaken). Note that this was true for a Portuguese model.
Edited by niant
Link to comment
That's quite weird... As far I remember when I reached 15,000 km I had the same warnings, and after the check up no warnings were display (I guess this was rebooted during the inspection)
The warning itself is a message and a sound. I just can't seem able to find any answers around the internet...
Link to comment
Follow the procedure you have been doing. But before you start, put your hazard lights on. Found it on a vw forum, and it works.
wow really? I will try this one next time! Thank you!
Link to comment
  • 1 year later...
  • 1 year later...
On 24.09.2017 at 19:44, SammyK said:
I tried with the flashers and it said it was reset but then a second later the "inspect now" message came back again.  Any ideas?
Actually no. I did that several times and it worked.
Did u switched on hazard lights before putting key in?
Link to comment
My car is keyless. I put on the flashers. Then held down the reset button. Then turned on the ignition. Then released the reset button. It asked if I’m sure I want to reset. I clicked OK. It displayed that it was reset for a few seconds and then the inspection now warning displayed again.
Link to comment
After putting on the flashers you have to turn on the ignition and when in turned on u have to held down the reset button.
Link to comment
  • 1 year later...
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
