Recommended Posts
Hello guys,
I'm new here and I want to ask you guys a question.
It's about my Škoda Fabia I power windows, right to be precise, front seat passenger.
The button is lowering the window glass, but it cannot get it up.
And the thing is even funnier from here.
I can close my right windows with a switch from drivers seat.
Is it broker or I can fix it.
And the model is Škoda Fabia I Combi.
Thanks. :D
Link to comment
Share on other sites
Are you saying the 1 touch up/down setting isn't working on the drivers side switch? - Has the battery recently been disconnected?
The system may just want resetting. Basically lower the window, then let go and click it down again to set the lowest point. Raise the window and when it's closed click it up to set the top position.
The passenger switch isn't 1 touch up/down.
Not sure if that's of any help but if that doesn't work you could well have some other issue.
Link to comment
No,no,no :D
You have driver seat and a front passenger seat, if you can understand me :D
And I have: Left from my driver seat 2 sets of buttons for closing and opening the windows on my car :D
Left window (Next to my driver seat is working), but the right window (next to a fron passenger seat) can only lower the glass, and can't get it up, I mean I can only open my right window and i cant close it down
And I sad ,you have two sets of buttons on the left door (driver seat) , and using them i can close it like normal :D
Do you understand what I'm saying ? :D
Link to comment
I forgot about that, hahahaha, sorry :D
Yes the issue is the passenger switch :D
From driver seat I can close both windows, but as a front passenger I can only open my window (On the right side) , can't close it down, so I think that it isn't broken :D
Any ideas? :D
Edited by Boslo
Link to comment
Any ideas? :D
Yes ..replace the switch that isn't working properly?
Link to comment
No,no,no :D
Sorry can't help then, sounds like a different layout to that of the hatchback/vRS! Does sound like an issue with the switch/relay from what your saying. I'm guessing your's also isn't a UK car if your saying the drivers side is on the left! - That's what confused me!
Link to comment
Is that so? :D
Alright, I just asked maybe you guys knew something, some kind of a trick, because I don't think that it's broken. :D
Thank you. :D
think it's fairly common for the switches to break, from what I've read on here, not seen any suggested fix though.
You could try using contact cleaner or something, but that's just a wild shot and unless you already have some it would cost just as much to buy a used part.
Link to comment
Yes it isn't a UK car. It from Austria, I think, so the driver side is on the left. :D
I will probably go to see my mechanic, he will know what to do.
Thank you for your help. :D
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
