Rteverse camera help!
Recommended Posts
Guest ProfesorDeBuceo
The Kufatec isn't cheap, but works really well -- and personally I wouldn't waste my money on a system that only costs 20 quid. You get what you pay for.
Mike
Seconded :thumbup:
Link to comment
Share on other sites
Thanks Mike that helps me out a lot , it's not too bad price wise but then again you pay a lot for the car so you don't wanner risk damaging it , how is it to code in and getting it to show up on Columbus ? Cheers
Link to comment
Mike,
Is yours a 'Highline' controller where the lines on screen bend as your turn the steering wheel?
I fancy doing this on my Yeti as I'll be pulling lots of trim out soon anyway.
Link to comment
I have never understood the need for the lines to move with the highline camera setup.  I am pretty sure Mike's is a so-called lowline setup though.
Adam
Link to comment
It was the RVC controller I was referring to. The 'highline' one uses feedback from the steering angle sensor to calculate where the car will go while in reverse and bends the lines on the screen to show the driver whether they are going to hit or miss something.
Like PDC sensors with OPS, it's not essential but if I'm going to do it then I want it all!
Link to comment
Probably not. But each to their own.
If I decide to fit a RVC (which I don't really need) or front sensors (which I don't really need), then I'll want to get the maximum functionality I can get.
Hence why I went for a 170 Yeti Elegence with a sunroof...
Link to comment
As Adam says, it is really needed? I find the one I've got more than adequate, and you can see how close to things I can judge it without worry!
Mike
 Glad you're still enjoying it Mike, I reckon it was money well spent :yes:
Link to comment
Boot need to be modified with this cam/handle.
The hole in the boot is to small.
I got a camera from aliexpress like mikes. And a video-in kit from eBay.
In function my installation works exactly like mikes.
Total cost 80£
The installation took around 3 hours.
Edited by mbirkely
Link to comment
Thanks. I had seen it but was put off by the boot modification (enlarging the hole I presume) that would be needed.
Have been searching for a camera to fit the hole and ness going to source suitable cabling afterwards.
I think this may have to wait though...
Link to comment
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
