Tailgate Strut
briwy
Recommended Posts
Just had a tailgate strut go on our three year old. Bit odd as I thought these were gas struts but the old one had oil leaking out.
Got a new one from SGS Engineering in Derby for £16, five minute job to replace.
Edited by briwy
Link to comment
Share on other sites
The struts on mine have started squeaking when I close the tailgate. Is this a sign they are on the way out or do they need some sort of TLC and if so any recommendations?
Link to comment
Mine did that!  But a small squirt of WD40 aimed carefully into each of the end sockets of both struts cured the squeak immediately. Helps penetrate if you twist the struts slightly on the sockets when applying the WD40, to give better access to the ball and socket joint.
Edited by FlintstoneR1
Link to comment
  • 1 year later...
After being hit on the head one too many times I did a search and found this thread.  Two struts are now en route to me from SGS thanks to this thread!
  • Like 1
Link to comment
Grease the fittings at each end only!
DO NOT put anything on the chrome rod the manufacturer says they  are totally maintenance free,
Often the cause of failure is the lubrication that has been put on the rods reacts with the seals and then eventually gas leaks out.  :o
  • Like 1
Link to comment
And that was that! They arrived today and took less than 2 minutes to fit (wife acting as a prop to hold the bootlid up). Now you have to be careful not to be caught under the chin as it goes up! One of the old ones was significantly weaker than the other it turns out.
Link to comment
Indeed. The reason I knew one had failed was that I could just about compress it with my full body weight on it. The other one remained unyielding under the same pressure.
I'm trying to think of ideas for how to over-engineer something at home with the old gas lifters.
Link to comment
Slightly off topic - can the tailgate opening be adjusted to prevent opening too high? I need it reduced by only about 40mm to prevent it clipping the roller shutter door to our garage.
Link to comment
I think the only way to achieve that would be to fit a tether or have shorter struts custom made.
Shame the tailgate opening cannot be limited via software like MB'S.
Link to comment
I'd guess that if you can find a strut for another car that is shorter AND has the same lifting capacity, that oughta do it.
Can you fit a padded bumper on the ceiling of the garage to catch the lid before it hits the door mechanism?
Link to comment
I wonder if I can re-purpose them (or one of them) as a bonnet lifter?
Link to comment
  • 11 months later...
Reply to an old post but it may be useful to know..
Our tailgate also clipped the roller door to our garage, so have fitted struts that are shorter.
The struts are Topran p/n 110279.
Equivalent to p/n 8D9827552F, original to Audi A3 8L rear.
According to specs they have similar lifting force to the Yeti originals but are 25mm shorter when fully extended.
Now, when opened,  the bottom edge of our tailgate is 158mm closer to the ground. Still plenty high and the grab handle is at a much friendlier height.
(Bottom of grab handle is at 173cm above ground.)
  • Like 2
  • Thanks 1
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
