Water in the spare wheel well.
Recommended Posts
Got the dreaded water in the wheel well in the Scout. PITA when living on the west coast of Scotland! A bit of investigation shows that it's entering the wheel well from a preformed hole in the metal skin of the boot under the plastic trim at the rear and towards the off-side. The question is how's in getting there. It's not from the rear wash wipe as the water has appeared with the car unused. Has anyone else experienced similar. Could it come from aerial or roof bar mountings leaking? I was thinking of changing the aerial amp as radio reception is poor. Could there be a connection?
Link to comment
Share on other sites
Thanks, I'll give that a check. I guess there must be a seal round the light clusters too, so I'll investigate there as well.
Link to comment
Yeh, definitely not screen wash related. Dried it out last night and then tonight more water and car hasn't been used.
Link to comment
If I could just get some dry weather I'd get out with the hose pipe and try to find the source of the ingress. Round the lights is certainly one area I'll be investigating though.
Link to comment
There have been reports of water entering through a damaged / perished rubber bung in the spare wheel well, but since your car hasn't moved for a while I guess you can rule this out.
Another common entry point on the estate is the high level brake light.
Edited by silver1011
Link to comment
Garage have reseated a rubber grommet where rear parking sensor wiring runs into body and say that's fixed it. Not had chance to test yet and currently enjoying some sunny weather (at last!) so will aim to confirm over weekend.
  • Like 1
Link to comment
I think the grommet is behind the bumper. From there it appears it was pooling in what I can only describe as a box section from where it was then running through an oval shape hole in the metal and into the wheel well. It's a lousy description, I know, but I suppose what I'm saying is that the grommet isn't actually in the wheel well!
Link to comment
Still got some water getting in. Going to need a big more investigation. Silver1011, you could yet be right.
Edited by Sarge
Link to comment
Try sitting in a closed boot (with a trusted helper)and a torch and ask them to hose the rear of the car down bit by bit.
I used to own a Morris Marina. It was well named and after sealing the rear lights it still leaked and then I drilled drain holes in the boot floor.
Link to comment
I can see where the water is entering the wheel well, just can't figure out how it gets to that point. Garage thought it was the grommet carrying the wiring for the rear park sensors but it's actually coming from above them. It's as though there's a double skin and I can see it's point of exit from the inner skin but can't see where it gets past the outer skin and into the gap in between, where it then seems to pool before overflowing into wheel well. Bit of a long shot but if bobt68 is still out there, did you solve your leak, because the description of your problem sounded very much the same as mine.
Link to comment
I had exactly the same problem.
I dried it all out then left it so I could hopefully trace where it was coming from.
It was leaking in through the rubber bung that the parking sensor wires go through.
I took it out, cleaned everything then smothered it with some Loctite flange sealant I had lying around. I chose this stuff and it never truly sets and remains flexible but is fully water repellent.
Problem solved!
Phil
Link to comment
Have you tried squeezing the rubber seal around the boot, down near the latch / lock mechanism?
There were reports that the drain holes in the seal were becoming blocked or were set in the wrong position preventing water from escaping.
Slamming the boot shut forced the water out of the seal and straight into the boot...
Link to comment
I did check this but the holes in the seal are on the bottom edge and do seem to work as I'm not getting a build up of water inside the seal itself. However I think I'm going to go back to checking all possibilities again!
Link to comment
Ok, update on this is car is back from garage and this time they replaced tailgate seal. My own testing seemed to suggest the aerial could be the problem but the garage checked this and couldn't find any ingress there. So I'll see how it goes over the weekend.
Link to comment
  • 6 months later...
Just had the same problem on my 2011, 1.4 TSI hatchback. Wife complained of a musty smell at rear and on investigation I found a swimming pool in me wheel well. I dried it out as best I could and left it for about 1/2 hour in the pouring rain. On returning, it had a little bit of water sitting in the well again. I checked the boot lid seal and, as said earlier, I found the seal drain hole at the uppermost point and a pool of water accumulating to the left of the boot lip as the car was parked leaning over to the left slightly. I cut two small holes with a scalpel at the lowest points in the seal and I was surprised as to how much water poured out from inside the seal!
Anyways, its now sitting outside in the rain and I'll post back if it has an effect.
Link to comment
My boot has been bone dry since I cut the holes in the seal.
Hopefully it will fix yours. If not then check the rubber bung in the wheel well as that was also leaking on mine (was filling up very quickly with both leaking!)
Phil
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
