ABS kicking in at low speed, now ABS/TCS light lit - no fault codes
Recommended Posts
On a recent trip up to Scotland the ABS started playing up on the car (2005 Mk1 vRS). It would kick in when coming to a stop but was OK when braking at higher speed. ABS light would illuminate and then turn off on a restart and the issue would happen again until eventually the ABS/TCS light came on permanently (which I assume means the ABS is now inactive). I've run a fault check with Torque but it doesn't show any codes - will vagcom? (I've read that the abs unit stores it's fault codes separately - is that right?)
ABS light illumination seemed to be related to steering angle before it went on permanently... On fairly straight roads it wouldn't turn on but when maneuvering in a car park it would illuminate.
Any thoughts?
Link to comment
Share on other sites
All the controller units store their fault codes locally, and the ABS unit is scanned by vagcom
The steering angle sensor (a small box attached to the steering column) do fail, replaced mine for about £70 from fleabay
The sensor then needs to be calibrated via vagcom
-start with a vagcom scan though :thumbup:
  • Like 1
Link to comment
with a VAG COM connected on ABS - Mesuring blocks drive the car slowly at 20-30 km/h and watch the speed of all 4 sensors,if one shows a different value you found the problem....if they all 4 show exactly the same speed you move on
  • Like 3
Link to comment
Ok, so to resurrect this post... A local member very kindly scanned the car today and it's showing a fault with the front left wheel. I changed the discs and pads on the front last week and the ABS ring looks fine but the ABS wiring loom down to the sensor looks like it's a bit knackered as I appear to have wrapped some insulating tape round it at some point. The fault manifested in the first place after a very very wet trip up to Scotland so I think it's probably a wiring fault rather than the sensor so that's what I want to try first. It makes sense to replace as much of the cable as I can to get rid of any corroded section near the broken insulation so does anyone know where you can get a replacement ABS plug with or without wire so I can cut the old one off and wire up and solder/crimp the new plug and wire in?
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
