1.9tdi ASV engine cutting out
Recommended Posts
Just to update my last thread .
My Octavia eligance starts fine hot or cold no smoke ticks over fine . First rev it cuts out ,wont restart .it turns over as if no compression then starts to fire on one cylinder then two three then runs smooth all the time smokeing like unburnt fuel,once its done this the smoke clears and it will rev fine . No fault codes no lights .ive changed immobiliser modified wireing
Vac pipes
Egr disconected and cleaned
Asv valve working fine
Coolent temp sensor
And today maf (topend reading over 370mg s ) haven't had it rechecked .both with gen Skoda items at great expense and its still doing the same .is there any one in the middlesborough area good with vcds that could look it over or any one got a next step for me.
Cheers for your time jim
Link to comment
Share on other sites
Has anyone ever had trouble with the fuel temp sensor in the injection pump? Started the beast today and gave it a rev and it faultered but dident cut out .new maf new cts only other temp related thing is fuel temp in pump. (only thinking this as its warmer today and temp makes a difrence it seems ) or am I missing something .im wateing to get my own vcds so I can go further into the figures . I'm thinking of takei g the belt covers off and checking the timeing belt all lines up ,I dident change it(was done before I got it) so its unknown even tho I've set it inspeck with vcds I'm wondering if I could be slightly out? Phisacly .its strange how it starts fine and drives well loads of power just that first hard set off or rev from cold upsets the apple cart
Jim
Link to comment
Wireing looks pretty good all conectors are clean . Took out the pressure valve in the ip and the retaining coller was halfway out so I've pressed it back in and refitted it .Il do the test in the morn see if its made any diffrance . Il try post up a pic .
Jim
Link to comment
i had the exact same symptoms but mine did it when i booted it hard, then it cut out.
for me, i had a replacement turbo, and it needed the vanes unsticking, as they were stuck in a position, and the turbo was overboosting!
Link to comment
Well it started worse than ever loads of air in the fuel lines and still cutting out . .to be fair I haven't bled the system after refitted the valve so its just reserculating the air I've let in i think . I've had a look at turbo and the vnt rods moveing on and off fine when vac is applyed also geting no boost faults coming up .
Link to comment
Well I've removed the flap valve in the tank sender feed .inspected the tank ,no gunk and very little metal speckles changed fuel filter and air filter re bleed the system and tested . Just the same . I did however not try to restart the car once it had cut out ,instead I left it and tryed a restart a couple of hours later and it started no problem im begining to think its in the pump, temp sender quanty adjuster whatever alters advance retard.wateing for my copy of vcds to get some figures before I pull the pump apart . I will beat this fault . Jim any one been into a tdi pump before?
Link to comment
Right I think I'm geting valve jack . To much oil pressure causing the tappits to expand enough to open valves to drop compression. I've now flushed the oil and replaced it with 5/30 fully synthetic vag spec .if it still persists Il have to find and remove the pressure relief valve ? Any ideas ?
Jim
Link to comment
I believe I've sorted it . Flushing the oil and new 5 30synthetic vag spec . Going to wash down and check for leeks and flush again after some miles on it . Apparently there's a pressure relief valve at the pump set at 170psi as a safety incase of major blockages and a second set to 60psi in the filter houseing ( the one I thinks sticking) also a by pass incase the filter gets blocked .
Il keep an update as I use the beast . Cheers for the help Jim
Edited by jublybug
Link to comment
Jim
Just to check our mutual understanding; is this phenomenon also known as "tappet pump"?
Link to comment
I have but never experienced it on an engine before . So it took some tracking down .i ended sorting other problems and fault codes aswell along the way. Just hoping the smoke clears up once its on the road (I'm thinking the amount of times its cut out its just un burnd diesel sat in the cat and exhaust system ) if it doesn't then could be bad injector dripping maby or turbo?
Jim
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
