Air temp sensor
Recommended Posts
in front of rad easy to pop off. Mine read wrong took it off to have a look, popped it back into place and it worked as it should.
Link to comment
Share on other sites
It's a really stupid design - the sensor is stuck out in the front of the radiator and has an exposed cable connector with no protective boot. You can see the separate wire cores in the harness. Other connectors in far less exposed positions on the same vehicle have boots...
My car used to give stupid temperature readings each time I washed it with a hose. Self-amalgamating tape covering the connector to cable junction cured the problem - replacing the omitted boot.
rotodiesel.
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
