OCTAVIA MK2 BODY CONTROL MODULE
Recommended Posts
Hi.  My wife's 2006 Octavia Mk2 estate has a non-functioning brake light.  Our mechanic has traced it to the body control module, part number 3C0 937049 E.  This part appears to fit lots of different VAG cars.  If I bought this part but it came from a different car, would it still work on the Octavia?  Would any reprogramming be required?
Thanks and regards
Jude Burcombe
Link to comment
Share on other sites
No, doesn't store the remotes. I changed mine on my Scout last year, to one from a Passat. The only thing that I ended up changing to match the Octavia was a brightness level on the rear tail-lights. Old one is still on my desk (nice paper-weight ;) ) Only changed mine so I could get cornering lights. ;)
Took about 15 minutes to swap out. A code check/reset should only add about 10 to that at the most.
No special tools needed, other than VCDS. :)
Oh and it's the Central Electrics Control Module (CECM). BCM was on the later ones (facelift) ;)
Link to comment
I thought it was the CCM...lol too many ccccccc's
Yeah, I feel your pain on that one ;) ;)
CCM is the Comfort Control Module ;)
Link to comment
It is, BCM replaced CECM during the facelife. CECM and BCM are also not interchangable either. (Different connectors for starters)
Not only that, but a 2006 will be a 23-byte CECM instead of a 30-byte one. The only major difference is the 30-byte will give you cornering lights.
Link to comment
Many thanks chaps.  The car has fogs but not cornering lights (as far as I am aware).  So if I get a 23-byte CECM with the correct part number I should be OK?
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
