VCDS Tweaks for Mk3 Fabia
Recommended Posts
So, I was thinking... I absolutely will be arranging a few tweaks when I get my car. The following are what I have in mind:
Dial staging
Coming/leaving home via fog lights
Door unlock on ignition off
Door lock after ignition on
Teardrop wipes
Auto rain sensing wipers (I have the SEO Auto dimming and tunnel function, so I'm assuming rain wipers can be switched on?)
Do you think it's possible to have mirror dip activated on switching to reverse gear? Or any other useful tweaks that come to mind?
Link to comment
Share on other sites
I don't think mirror dip is a VCDS only tweak, as it requires specific hardware as well. In some other models it required electric seats to get the mirror dip, and as those are not available for the Fabia, I think you are out of luck with that one
Link to comment
Ah, it felt like a long shot anyway! I guess a mini-dome disc glued onto the passenger side mirror and will have to do! Thanks for the intel the_raz, and yep just noticed it as a Bolero setting on the manual so cheers for the heads-up looking_to_buy!
Link to comment
Auto locking isn't actually settable on the Bolero, despite what the manual says. My dealer activated mine.
Link to comment
As they should if you want.
You buy a new car & the Engineers / Designers gave it functions you paid for, the Vendor should ask you which you want to operate which
way if it requires being done at a 'Dealership'.
Done free as well, at PDI if they ask you before hand or at Hand Over if they forget, or just do not bother to ask.
Your property, and if it can not be made to function or be inhibited by the driver / owner.
Link to comment
Yep, just emailed the dealer and they'll activate it. Thanks for the heads up everyone!
Any other thoughts on interesting and useful VCDS tweaks for the Mk3 Fabia?
Link to comment
Just a heads up, but on the Octavia/Golf (MQB) there are several sub menus/activations which are coded info the infotainment (even the basic one) but are set to "not active" in VCDS, so just set to active along with certain other channels & hey presto, you have loads of drop down user changeable options on your infotainment!
Virtually all the modules are flashed with the full list of "options/functions" just the ones that the importer thinks are acceptable are actually revealed at the factory! If the hardware is there then activate it!
Common VCDS tweaks on MQB
needle sweep
honeycomb display background for MFD (colour)
window close from key fob
alarm chirp for lock/unlock selectable
selective unlock
rain close for windows
SOC display in MFD
Oil temp display for MFD
Refuel amount display in MFD
anti-hijack
front fogs as coming leaving home
front fogs as flash beam
DRL's dim when indicators on
tailgate lights off when tailgate open
And loads more..............all VCDS tweaks if you have the hardware there, & the amount I have altered on my car is mind boggling......so don't despair just get VCDS, do a full auto-scan of the car & then a full Adaptions map of each module, so you then have a complete coding & adaptions list of the car as it was before you started tweaking!................. :happy:
  • Like 4
Link to comment
That's really helpful fabdavrav! Do you know which tweaks are specifically available on the Fabia?
Link to comment
There's a bit more to it... You need a specific VAG Com cable which is near enough £300 here in the UK. So maybe ask around for someone with a cable or go to a local VW Group private garage and some of the technicians there may be able to do it for you.
Link to comment
What about this cable: < Link to fake cable removed>
It says it supports to 2013 models, so for later ones you need different cable?
Edited by mannyo
Remove link to counterfeit fake cable
Link to comment
Ta
That cable is a fake cable using hacked software, the official VCDS is around £300, anything around £70-100 claiming to be Canbus compatible is a fake, of which discussion on Briskoda along with links to these cables are not allowed.
Rosstech have invested a lot of money developing the software and buying cars to test it, along with helping some on Briskoda and other forums.
Link to comment
That will work with versions up to about 12.12........................you will not be able to download & work the latest versions 14.10 plus which you need to use on the new cars because the coding is more advanced!!!!
As for this items being a definitive list, no it isn't as I haven't done a full ad map of a new Fabia, so it is just speculation on my part. It is easy to do this with VCDS & then start altering a small amount at a time ( make back up copies & list all mods) & there is a debug function in VCDS............
Link to comment
Ta
Thanks for the information, have now lot more knowledge of this cable.
When buying new cable and software, will it work on new fabia and last year VW Golf Sportsvan?
Link to comment
ALL VAG going back 15yrs................AT least!!!!
Skoda, VW, Audi, Seat, Commercial VW, some forklifts, some Bentley
EDIT found this on Ross-Tech website:-
1.1  Will VCDS work with my car?
VCDS and VCDS-Mobile will work with most
and
models sold
World-Wide
1994 through the current model year. It will work with some cars all the way back to model year 1990. It will also work with most late-model
, and
models sold in markets other than North America. If your VW or Audi has a
,  VCDS will definitely work.  If your car has the old
, check if there is a wire going to each pin, as shown in the picture. If there are four wires, VCDS should work with any diagnostics-capable modules that are present.  If there are only three wires, then nothing in the car is diagnostics-capable..  Please see these
where you can select your model and see which modules can communicate with VCDS.  Also see the
for a few things that may not work as expected.   If in doubt,
us.
Edited by fabdavrav
Link to comment
My DRL,s flash alternatly with in Indicater's, looks really cool
yep, "Blinken hellphase" I think is the term................decided to just have mine dim to 26% instead of D.........I..........S.......C..........O................ :dance:
Link to comment
I've also had the brightness of the DRL's in side light mode increased to 60%. Looks a lot better but not to bright as to hit you in the face
Link to comment
Yup did that too, but to 50%...........also did the parking light (stationary) to 26%, then the drls & front fogs as flash beam when xenons off, tailgate lights which off when you open it so you don't blind yourself with the number plate lights............everything on the list plus more...............
Link to comment
  • 2 months later...
Can someone tell me where the OBD2 port is on the new Fabia? Not had a look yet, the wife has just received her car and the dealer told me the auto lock could be activated via the head unit even though I explained that I thought it had to be plugged in.
Also, is it possible to make any adjustments via an android phone app? If so, what is possible and what is not? What is the best app? Is it worth getting a paid version?
Has anyone plugged in and connected an app to the new Fabia?
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
