Coding the bulbs to LEDs?
Grumpy Finn
Recommended Posts
I like to code all the interior light types from the bulbs to the leds. Does somebody knows the light codes?
- Footwell lights: (1)-Leuchte30FR LC72-Lasttyp 30 (from 20 - 4*5W to 43 - allgemaine LED)
- Door warning lights: ?
- Glovebox light: ?
- Trunk lights: ?
- Ceiling lights front: ?
- Ceiling lights back: ?
I have replaced all the bulbs with Narva: http://www.narva-light.com/en_EN/products/led_types/led_types/18001 (expect the trunk has SuperSkoda: http://www.superskoda.com/Skoda/OCTAVIA-III/Octavia-III-MEGA-POWER-LED-cargo-trunk-light-KI-R).
Edited by Grumpy Finn
Link to comment
Share on other sites
None should need coding as they're not monitored. I changed all my interior over to LED, plus the doors (inside and outside) no problems. :)
Link to comment
You are right. I have found only these which have 5W bulb:
- (1)-Leuchte30FR LC72-Lasttyp 30 (has 20 - 4*5W)
- (1)-Leuchte25KZL HA59-Lasttyp 25 (has 18 - 2*5W)
Link to comment
The reason to change the lamp types was this, when I changed all the 5W bulbs to LEDs, there were two faults:
Address 42: Door Elect, Driver (J386)       Labels: 5QX-959-X93-42.clb
   Part No SW: 5Q4 959 593 C    HW: 5Q4 959 593 B
   Component: TSG FS        009 0015
   Serial number: 0000139079001
   Coding: 00150920D000040000001100
   Shop #: WSC 73430 790 00212
   ASAM Dataset: EV_DCUDriveSideEWMAXCONT 006001
   ROD: EV_DCUDriveSideEWMAXCONT.rod
   VCID: 45B9130DC466E0091D9-8010
   Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A
   Component: FOND_FHSG_DRV  005 0005
   Serial number: 00000000000005325057
   Coding: 010200
1 Fault Found:
65604 - Door Warning Lamp
          B1326 01 [009] - Electrical Failure
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 31
                    Mileage: 1119 km
                    Date: 2015.05.10
                    Time: 11:08:16
Address 52: Door Elect, Pass. (J387)       Labels: 5QX-959-X92-52.clb
   Part No SW: 5Q4 959 592 C    HW: 5Q4 959 592 B
   Component: TSG BFS       009 0015
   Serial number: 0000138903077
   Coding: 00150120D000040000001100
   ASAM Dataset: EV_DCUPasseSideEWMAXCONT 006001
   ROD: EV_DCUPasseSideEWMAXCONT.rod
   VCID: 44BF0E09CF5CD9010A7-8011
   Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A
   Component: FOND_FHSG_PSG  005 0005
   Serial number: 00000000000005309212
   Coding: 190200
1 Fault Found:
          B1326 01 [008] - Electrical Failure
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 7
                    Reset counter: 71
                    Mileage: 1119 km
                    Date: 2015.05.10
                    Time: 11:11:40
Link to comment
Have you tried clearing the codes to see what are still current?
Some models do indeed monitor the door open warning lamp, but once a CANBUS LED is in place the DTC can be cleared and will stay cleared.
The rest of the interior bulbs should not be monitored (I used CANBUS LED’s throughout the car as it was easier to buy 20 CANBUS LEDs than to mix and match them.)
Link to comment
I have cleared the codes, seems to appear again. Following the codes, now I have the original bulbs. Maybe I buy the SuperSkoda Power LEDs when ordering something from them again.
Link to comment
No issues at all on mine, puddle lights and door lights are LED.
I was a little surprised, as my O2 didn't like LEDs in the puddle lights.
They aren't CANBUS ones as they throw an error in the sidelights and the reversing lights until coded for LED.
Sent from my HTC One_M8 using Tapatalk
Link to comment
  • 1 year later...
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
