Changing whole drivers door
Recommended Posts
Does anyone know whats included in changing a whole door out? so far I believe it's this -
1) possibly recode door control module
2) change key barrel lock
Is this everything? Is it fairly easy to switch over the key barrel lock.
Link to comment
Share on other sites
Not difficult two screws on door barrel and recode on window motor control module.
Link to comment
As above, hardest bit is wiggling out the lock barrel and getting the mech out passed the regulator. On the barrel is a small retaining screw, loosen but don't undo or drop it. And the main retainer below takes at least a dozen turns iirc, keep going until you feel resistance then stop. Then get wiggling. Note the position of the external handle cable in the teeth and fit in a similar position to ensure tension when you pull the handle.
  • Like 1
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
