Change head gasket? Skoda Fabia 2002 1.4 8V MPI
Recommended Posts
These are the only faults I'm getting since 2013. My pre-cat lambda probe heater is pretty tired. I've tried once to repair it, it held for a while, but less than two months. It's a shot resistor.
3 Faults Found:
16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
            P0130 - 35-00 -  -
17584 - Bank1: O2 (Lambda) Correction Behind Catalyst: Control Limit Reached
            P1176 - 35-10 -  -  - Intermittent
16554 - Fuel Trim; Bank 1: Malfunction
            P0170 - 35-10 -  -  - Intermittent
Readiness: 0010 0001
I've double checked this morning, both crankcase ventilation hoses are in mint condition. I'd like to have a better mpg, but I don't think I'm going to be able to do this until I'll replace the faulty Oxygen probe.
TMB, could you recommend me anything else that I should check ? :)
Link to comment
Share on other sites
Blimey!
SWMBO's can't get above 34mpg when I kept track of her usage for a few months.
Maybe I need to look at her engine...
Link to comment
Not unless you're having any other problems :)
I wouldn't bother checking with a vacuum gauge. As long as there's suction you should be good.
Link to comment
Haha cool! By the way, is there a permanent fix of the water draining hole from under the windscreen wipers, the one from the engine compartment? If I am not checking it, it gets stuck with filth and rain water gets into the car, at the passengers feet and the polen filter has to be replaced.
Edited by Alexandru
Link to comment
Not sure Alex, I've never had a problem with that up to now.
I think I get around 300 miles a tank around town but it's far better on a long motorway run.
Link to comment
My journey is over now, I'm back home. These are my thoughts with a fully serviced 15 years old car. Going on B roads without AC and with speeds that didn't exceed 50-55mph, with 2 passengers and a full boot, I got about 51mpg. With only 1 passenger, boot almost full, with AC on and driving with 70-75mph, I was getting about 35mpg. That's quite a difference I can say.
offtopic: With a new car, you can feel one or two bumps when opening wide one of the doors. Is there anything I could do to restore that thing?
Link to comment
I am running around in a 1.4 mpi at the moment and im getting silly fuel economy its in the range of 50mpg.
No engine management light but a fault code reader which does real time measurements reads a fixed 1.2VDC for the lambda which i believe its a rich state so is always trying to lean out the burn hence the fuel economy.
But all 4 spark plugs are a light brown with white patches which shows it is burning lean.
I reckon its a faulty lambda sensor but unplugging it doesnt flag an eml so i could be onto a different fault.
Does yours have anything like that? Id never expect more than 40mpg in one lf these engines to be honest
Link to comment
You mean the door check strap thingy?
http://www.briskoda.net/forums/topic/314587-door-check-strap/
Yep, I was referring about that door arrester. I'm not sure if I should replace it, since it's not broken.
Before starting to replace things, I'd recommend you to run an emissions test.
Link to comment
Have in mind that you might need to replace a lot of things along with the engine, such as transmission components (gear box, driveshafts), electronics (ECU, immo etc) and you might have a few legal issues as well. In my country it's a bit complicated to fit an engine from the same car/model, but with different specs and you need an approval, the car has to be tested on a dyno etc. In some cases, it's cheaper and easier to sell the car, have a few money extra and buy a different car.
Link to comment
@TMB: I'm not sure if it is related to that vacuum hose that I've replaced, but it seems that I've lost a few fault codes since I've replaced it.
what I was getting:
3 Faults Found:
            P0130 - 35-00 -  -
and this is what I've got this morning:
1 Fault Found:
            P0130 - 35-00 -  -
Should they be related somehow ? I don't get it ...
Link to comment
what I was getting:
3 Faults Found:
            P0130 - 35-00 -  -
1 Fault Found:
            P0130 - 35-00 -  -
You had an air leak which was letting fresh air into the inlet, bypassing the throttle, in quantities that would be inversely proportional to engine load (biggest rate of leak at idle with lowest pressure in inlet manifold, smallest leak at WOT when there would be nearly no suction from the manifold). That could easily confuse the ECU and generate some fuel trim issues?
I think the rates of blow-by (and low oxygen content of it) at idle would mean that the situation would be quite different to this with an intact hose.
Try disconnecting that hose which you replaced, and see if the faults come back, if you are feeling 'experimental'. :)
Link to comment
That makes perfect sense ! My engine is showing a strange symptom for the last few days though. When performing acrobatic moves to leave the work parking lot, it's trying to die. The rpms are dropping to 600 or maybe lower for a fraction of a second when changing gears from reverse to 1st or vice versa, keeping one foot on the brake and one on the clutch and rolling the steering wheel all the way from left to right. It never stalled, there are no error logs that might indicate something really bad. Basically it's just dropping from 1800-2000rpms or anything I'm telling her to do .. to 5-600rpms instead of going into the 800 area, as it should be.
Should I check for another leaking vacuum hose or air leak in the intake system ?
Link to comment
If you have reset the fault codes that will reset the fuel trim (it's an apaptive learned value). Still have an electrical fault with the lambda probe. If you are lucky it's a probs, if you are unlucky the loom has probably sucked up water under the battery area and corroded the loom.
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
