Skoda Dealers; Air Con Check and Brake Fluid Change May 1st to 31stJune
gumdrop
Recommended Posts
So they changed the brake fluid, but the re-gassing took a
turn for the worst. A hole in the condenser, new one required,
£498 please (inc. £160 labour.)
Link to comment
Share on other sites
'What you never had you might not miss'.
If the A/C has not been working and you never noticed, is it worth getting repaired?
Obviously it is, but then many never bother doing so, and when the car is traded in a Dealer Never checks and the next owner
discovers or not that the A/C does not work.
Link to comment
You could try a Local, car Radiator service repairers.
Or
Euro car parts start at £79............http://www.eurocarparts.com/ecp/p/car-parts/car-cooling-parts-and-car-heating/air-conditioning1/air-conditioning-condenser/?222440611&1&219e43aa7d128baab1c2cfd9349496d11253b0bc&000382
Then take it to an independant air con regas.
Link to comment
Use your Local air con re-gassers. Or your Local garage.
Not a difficult job at all.
Take in the part you purchased and walla.
Just because it says Skoda on an expensive name plate above the door doesnt mean they are any more Pro than anyone else.
And if it saves £200 quid, I'm all for that.
Of course get a quote first from the Air con people, then compare.
Link to comment
Get the dealer to put in a claim to Skoda UK - the condenser unit has changed design to prevent holing and from what I have read, Skoda will cover the cost of replacement since the original one was flawed in design.
Link to comment
If it's near 'trade time' would you bother, remembering the dealer will do it at a lower cost to himself for resale, obviously.
You could use it as an excuse for a new car )))
Link to comment
I drove to Castle Cary and back today to collect my caravan and without
air con .....  It Was Hot, even the windows open only brought in warm humid air
So I have given them the go ahead to fit a new unit.
Now I need to improve the protection for the new unit
some sort of Stone Guard, a stainless steel wire mesh?
is there such a thing?or shall I have to make my own?
Link to comment
There is a thread on here (in the Yeti technical guides I think) where someone fitted stone protectors to their upper and lower grills.
I keep looking at mine and thinking...
Link to comment
Apparently there are vw/skoda guards for the condenser
Protector. 1KO 820 746 1-off @ £6.41 each + VAT
Securing Clips. 3DO 867 646 8-off @ £0.28 each + VAT
I cannot get the part numbers recognised by dealers (surprise!)
I have located the necessary mesh and have a Winter Grill Cover
to use as a pattern (or even use it as a fitting with the mesh in it)
Link to comment
Looking on You Tube, I found (among many by this company) an
idea of what may suit the Yeti.
The mesh is too small on this installation but you get the idea.
A few mesh choices.
http://www.carbuildersolutions.com/uk/tube-sheet-and-materials-aluminium-and-stainless-grill-mesh
Edited by gumdrop
Link to comment
Re post # 16.
'Simply Clever', Skoda can protect the Condenser as OEM.
I cannot find any Skoda solution to protecting the Condenser,
please enlighten me :D
Edited by gumdrop
Link to comment
Skoda could use the solution that the DIY people are using once they have had to replace the OEM one usually.
Head for thinking, feet for dancing,
Replacement parts counter for profits,
and if everything lasted for ever you would not need replacement OEM or even Pattern Parts.
Link to comment
Err is there a void in here... in 2013 Skoda changed the design of the condenser to reduce the risk of it getting holed.
And it should be fitted FOR FREE if your first one has been holed.
I did say this in post #8 but it seems nobody is listening???
Link to comment
Interesting.
Do you have a link to that offer?
Link to comment
no they are too busy reading...teheeeee.
  • Like 1
Link to comment
I read post #8.
It said "from what i have read".
& post #21
'It Should be FREE".
So is it the case?
 or is it the Case of 'If you do not ask a Dealership or Skoda UK CS you will not know, but someone on the forum has read it and
it Could, Should, Might or Might not be the case?
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
