Faultcode p2452
Recommended Posts
Hi.
Ive got a faultcode p2452 "diesel particulate filter differential pressure sensor circuit".
Anyone here have som more info about it? Is it the sensor itself being faulty? If so, is it easy to repace by myself?
Link to comment
Share on other sites
Okey, so I think I found the problem:
https://drive.google.com/file/d/0BzLjWTS5DMAfNVFNRjAwZndJMDg/view?usp=sharing
I cant imagine the left hose ending up in thin air, the bad thing is I cant find the other end that's coming up from the DPF.
Suggestions on where it might be? I dont even know where it's supposed to come up into the engine area.
The controllamp did not light up after starting the car today. I resetted the fault code but I got the same one again instantly.
Regards,
Kim.
Edited by kimpis
Link to comment
does a DPF have rubber hoses on it? its in the exhaust system, metal pipes, etc....
It does on my Octavia, the two pipes which to the differential pressure sensor from the different are rubber.
Sent from my D5803 using Tapatalk
Link to comment
Possible Causes
  • Fuse(s) faulty
Wiring and/or Connector(s) from/to Exhaust Pressure Sensor 1 (G450) faulty
Possible Solutions
  • Check Fuse(s)
Check Wiring and/or Connector(s) from/to Exhaust Pressure Sensor 1 (G450)
Check/Replace Exhaust Pressure Sensor 1 (G450)
  • Check Measuring Values
  • Like 1
Link to comment
Well, had the car turned in to the repair shop the day before yesterday.
The sensor itself cost around £90 and the change, calibration and reset of the fault code cost me £20.
All good now :)
Thanks for the input.
  • Like 2
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
