FIXED vrs idle shake
Recommended Posts
I cant believe the cam has no damage either but ive seen it and it looks spot on, im wondering id someone replaced the cam at some point to try and resolve the issue.
Hopefully it will fix it 100%
Bless, the only way to check a cam for wear is with a DTI, you may well have great eyesight Jon but I doubt even you can see 10 thou missing from the base circle  :p
Link to comment
Share on other sites
Hopefully they are checking your oil pressure once its back together?
I hope so to!
Agreed, just surprised its go no sign of any damage
Link to comment
Any news?
I've rebuild / rebuilding one currently with a worn cam and tappets. Took a picture of the tappets since it had worn all the way through and worn almost the full cam lobe off!
Were you able to see the engine running before you started or did it arrive to you just as an engine?
I'm still keen to know more about the symptoms of this as I have a horrible feeling I may be suffering from it. However my symptoms (car shaking/roughish idle on occasion) are intermittent.
  • Like 1
Link to comment
Yeah I seen it running, I drove it.
Had a misfire fault code it was that bad, so very shaky and rough on idle. Was one of the worst I've seen.
If your on your phone, turn the brightness up and zoom in on the left bucket, it's very very dented and has a hole in. Bucket 1, bucket 3 and bucket 8 were all dented, cracked and had holes in.
Camshaft is ruined, I'll get more pictures tomorrow now they are all removed.
Link to comment
Had a misfire fault code it was that bad, so very shaky and rough on idle. Was one of the worst I've seen.image.jpg
God almighty, what the hell has caused that?! Or don't you know? Surely that just can't be classed as "wear and tear" lol
Link to comment
This was mine was the worst one, had a big hairline crack init and worn, I never had any shakes tho, mine was just a rough start. Has a full skoda service history too.
8D7CC953-89C3-40D9-8143-CBE3238A3351_zps
1F0A9DE9-EA14-4FFA-94B9-4CCE7E841809_zps
Link to comment
I've always fitted the Darkside forged steel camshaft:
http://www.darksidedevelopments.co.uk/products/complete-camshaft-kit-for-1-9-8v-pd-engines.html
I know the one iipaul bought has just came back into stock and his was good as well as forged steel for almost 50% cheaper. This one:
http://pages.ebay.com/link/?nav=item.view&alt=web&id=150912327519&globalID=EBAY-GB
You get bonus pub talk points for that one as well since you can say you have a BCD Racing forged steel camshaft
Timing belt I always ask for dayco on my vag stuff
  • Like 1
Link to comment
I'd go for the piper fast road cam, when my friend fitted one in his Octavia it was brilliant!
The lifters cost more than the cam though! :o so he fitted the black lifters that most people do, not the ones from piper.
Link to comment
Starting to think that the rough start I'm getting and rough idle could be camshaft wear, even though it looked in good condition when I took the cover off a couple days ago to adjust the injectors.
Might inspect it again tomorrow.
Link to comment
I think I'm going to check mine over the weekend. Slightly off topic but what do you personally use to seal the cam cover back on? Is it a gasket and also sealant?
Link to comment
No sealant at all, Just the rubber gasket.
I hate seeing the rocker covers plasterd with bathroom sealant to seal it... They are about a tena for a new one.
Link to comment
Link to comment
I believe that's the red sealant for the edges of the rocker.
I never have and never had a leak.
Edit:
Not saying I know better, but I've never seen a gasket paste used on a new rocker cover before, even at the dealership and independent VAG specialists. I've seen people clag the full rubber gasket with silicone sealant and it's awful.
Link to comment
Got a link to the PD cam you'd put in yours?
They don't advertise it for some reason, which I find a tad strange, so you have to call them about it for any info.
They're based only 2 mins up the road from me
http://www.pipercams.co.uk/pipercams/www/contact.php
Pretty sure they keep one on the shelf.
Link to comment
Edit:
As a side note, I've also had my rocker cover off almost 10 times and never changed the gasket, it's never leaked, ever.
Link to comment
Cheers.
This looks a good kit;
http://m.ebay.co.uk/itm/151493581389?nav=SEARCH
Have asked them about which lifters they are.
They're based only 2 mins up the road from me http://www.pipercams.co.uk/pipercams/www/contact.php
Can you remember a rough price he paid? :)
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
