Cruise Fitting Errors
Recommended Posts
Just fitted the cruise control kit to my car.
Followed instructions perfectly however it does not kick in.
I've got an implausible signal error on the engine ECU. I've also noticed that even after activating, rather than having G000SG I've got G200SG??
I'm also not 100% sure I got the right wire on the ECU. I followed the guides and have attached it onto the only white wire in the big block plug.
Anyone got any advice? The cruise shows up on the central electrics section when you press the buttons etc all indicators change (EG: Reset section.)
Link to comment
Share on other sites
Thanks for everyone's help. I discovered I hadn't terminated it correctly on the ECU end of pin14. I had used a temporary solution just to test the system and it clearly didn't give good enough contact.
Doing the job properly the first time would have helped!!
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
