*SOLD* 2006 MK2 Octavia VRS, Stage 2 280bhp
Damo
Recommended Posts
Basics
2006 Octavia VRS
Corrida Red
125k miles
10 months MOT
Location Sheffield
FSH (Cam belt not due until Jan 2017)
In-Depth Spec
Engine and Tuning:
The car is Shark stage 2 (280 BHP / 330 Lb/Ft torque); with the following engine parts fitted:
- 3" Pipewerx 200 cell sports cat downpipe
- Milltek resonated catalytic converter back exhaust
- THS FR3 engine torque mount
- Audi S3 Intercooler
- Audi S3 Intercooler hoses
- Audi S3 Revision 'D' Diverter Valve
- Neuspeed Turbo Outlet Pipe
- Neuspeed Intercooler Charge Pipe
- Neuspeed P-Flo Intake
- Shark stage 2 software
- Forge Silicone Throttle Body Hose
- Revision N PCV
- N80 Valve
- MAF Sensor
- New radiator and coolant
- Water pump
- Cambelt
- New auxiliary belt
- NGK Iridium Spark Plugs #7
- Audi R8 Coil Packs and harness
- ECS Tuning aluminium oil filter housing
- ECS Tuning magnetic sump plug bolt
- New battery
Transmission
- Factory 6 speed
- Forge short shift kit
- New Helix Organic Clutch
- New DMF
- Fuchs Sintofluid
Suspension
- Bilstein B8 dampers
- H&R -50mm Lowering springs
- New Bump stops
- New Top Mounts
- Audi S3 Lower control arms/Bushes
Wheels
- Genuine Audi Ultra Sport 18x8J Alloys, refurbed in Anthracite
- Michelin PS3 tyres on rear
- Falken 453 tyres on front
Brakes
- EBC Front grooved disks
- Yellow Stuff pads
- Standard rears
Interior
- Pioneer DVD double din HU
- Bury Car kit
- New VRS mats
- New Superskoda rear blinds
- Briskoda B sticker on windscreen  :)
- All bulbs changed to LED's
- Colour coded fascia trim
Exterior
- Corrida Red Paint
- Black grille
- Black mirrors
- Superskoda honeycomb lower front grill
- Stone chip level raised and resprayed on Sideskirts to prevent rust
- Depo Headlights (Painted internally black)
- LED Number plate lights
- Briskoda stickers  :)
VCDS Coding
- Auto lock above 10MPH
- North America DRL Setting
- Dual Rear fog lights
Service History:
28/02/07 @ 16889 miles - oil and filter
14/01/08 @ 32350 miles - oil and filter
27/10/08 @ 43517 miles - oil and filter
03/06/09 @ 50839 miles - oil and filter; air filter
24/05/10 @ 64272 miles - oil and filter
04/08/11 @ 78116 miles - oil and filter; timing belt
10/07/12 @ 94296 miles - oil and filter
14/12/12 @ 95958 miles - spark plugs
08/01/13 @ 96479 miles - cam follower; timing belt; timing belt tensioner; water pump; air filter; rev 'D' Diverter Valve
23/02/13 @ 99577 miles - oil and filter; fuel filter; Neuspeed P-Flo fitted
07/06/13 @ 103651 miles - oil and filter
30/08/13 @ 106068 miles - MAF and PCV replaced; spark plugs
19/09/13 @ 106452 miles - oil and filter
01/02/14 @ no record - N80 Valve fitted to fix P0441 fault code
08/02/14 @ no record - Audi S3 Lower Control Arms fitted; Audi S3 intercooler pipe and hose fitted; new radiator fitted
12/04/14 @ 111445 miles - 4 Bilstein B8 dampers fitted; new top mounts; rear bump stops
15/05/14 @ 113868 miles - Forge Silicone Throttle Body Hose fitted; Neuspeed Turbo Outlet Pipe fitted; Neuspeed Intercooler Charge Pipe fitted; Milltek catalytic converter back exhaust fitted
17/07/14 @ 115239 miles - oil and filter
16/08/14 @ 116000 miles - Pipewerx 3" Downpipe with 200 cell sports catalytic converter fitted
26/08/14 @ 117071 miles - NGK spark plugs; R8 coil packs; 2.0 TFSI red wiring cover
18/12/14 @ 120746 miles - oil and filter
03/01/15 @ 120783 miles - oil and filter change again; o-ring didn't seal correctly causing a nice oil leak (replaced standard oil housing with ECS Tuning oil filter housing and ECS Tuning magnetic sump plug).
06/02/15 @ 122343 miles - auxiliary belt replaced
28/03/15 @ 123147 miles - New LUK DMF; Helix Organic Clutch kit fitted with new Concentric Slave Cylinder
I know I haven't had the car long, and I had planned on keeping it a while... but I really miss my old Superb (and I mean really :() and want to get another... so this beauty has to go. If I don't sell it it won't be the end of the world for me, but I have to scratch the Superb itch once more.
I bought the car off Stu08, another Briskodian, who'd had most of the mods done in his ownership.
His for sale thread is here > http://www.briskoda.net/forums/topic/351894-2006-mk2-octavia-vrs-20-tfsi-hatchback-stage-2-provisionally-sold/
I gave him £4k for the car, and have since spent just over £1k getting things that needed doing sorted.
This included:
£400 for a new a/c compressor and fitting, and regas
£350 on full front end respray to eradicate the many stone chips
£100 on a TTS replacement engine cover that fits with the induction kit
Also a couple of hundred pounds have been spent on minor modifications, including vinyl wrap, dash cam, pressed plates, plate surrounds and other bits and bobs to make it better.
Car was MOT'd on 07/05/15 and went through with no advisories
I can honestly say this car doesn't have any knocks/rattles/squeeks and really does feel like a car with only half the miles as everything has been replaced and improved.
It is definitely the fastest car I have owned, and the Shark map is so smooth and flawless, that you really do have to be careful with the right foot, so please bear that in mind if your thinking of buying it.
My build thread I started is here, with more pics > http://www.briskoda.net/forums/topic/355565-damos-2006-octavia-vrs/
All in all this is a great car, that has been made even better, and now looks as good as it drives.
As for the all important price, I paid £4k for it, and spent over £1k getting it mint, so I would be wanting £4750
Not a lot to pay for a very well sorted car
PM me for more info
Thanks for reading
Damo
(Please remember this is a for sale thread. Negative/unhelpful comments will be removed)
  • Like 2
Link to comment
Share on other sites
Surprised your selling it but you've got to do what you've got to do and all that. All the best with the sale a lovely car made even nicer, the only shame I was following your thread on this one LOL.
Thanks fella :thumbup:
Like I said, if it doesn't sell I'm not fussed, just missing my old superB.
Just been out in it to drop daughter off at work, and not sure whether I'm doing the right thing selling tbh.
But if its meant to be it will sell, if not then no worries.
Cheers for the kind words
  • Like 1
Link to comment
Wow,didnt expect this!,
In my eyes, one of the benchmarks for modded Mk2's, and the recent mods have only made it better.
GLWTS, someone's gonna get a great car!
  • Like 1
Link to comment
Glwts how come your selling damo fancy a change. Get a v6 superb lol
Wish I'd have kept my SuperB now :(
Really missing it
This is fast and fun, and a great car, but I like my SuperB's
Not in a rush though, if this sells then I'll find a good one then... But in the meantime I'm happy driving around in this
That V6 is nice, but I'm a Combi man in SuperB guise ;)
Link to comment
If I was looking for a quick family car, this one would be ideal.  I remember it when it was up for sale last time and now it's even tidier.  Good luck Damo as I'm sure someone will snap this up pretty quickly.
  • Like 2
Link to comment
Thanks for the kind words Simon.
Thought I'd have had a bit more interest from enthusiasts on here tbh.
Guessing I'm going to have to advertise it elsewhere... which is a shame :(
Link to comment
I went with Adrian Flux. £390 fully comp with all mods declared.
Very happy with that.
Better to go with specialist insurers, they are more understanding of modifications and it doesn't always mean the price will be that much higher
  • Like 2
Link to comment
Bloody hell :(
Why's this happening :(
I was gonna pick your brains for part and what to do next with mine :(
It might not happen yet mate
Still undecided, and not even advertised it elsewhere.
Every time I go for a drive, I just think I'm mad to sell it, it's awesome...
But I was mad to sell my Superb in the first place :(
  • Like 1
Link to comment
Air con has a slight leak, which my garage has traced down to the evaporater.
With that in mind I will drop the price to £4500
That is honestly the only thing that needs doing on this car
Anybody to view/drive won't be disappointed
Damo
Link to comment
Guest
  • Community Partner
  • Create New...
