Recommended Posts
Hi All,
I have started to get the smell of diesel fumes in my 58 plate 2.0litre 170 bhp DSG superb II.
Any ideas / questions?
Have you checked your exhaust for holes/leaks, at the engine manifold especially?  This could be one potential reason?  Could also be aircon system / filters?
  • Like 1
Link to comment
Share on other sites
  • 3 months later...
Assuming that you mean exhaust fumes. There are multiple places that fumes can leak from in a modern car but a common one for diesels can be a failed EGR valve. As a priority I would check the CO levels in the car if you are unable to get it checked properly in the short term as exhaust gases are not healthy for those inside.
The trick we always used to do in the workshop of the family garage was to get someone to block the end of the exhaust with a rag while another person looks for leaks through the system.
Also, It may not be exhaust gases and could be oil dripping on something hot as Oil fumes smell very similar to diesel fumes.
Edited by Pesmog
Link to comment
Thanks guys, I did put my hand over the exhaust.
Two things happened:-
1/ I burned my hand (apparently modern day engines have hotter exhausts than old minis.
2/ There were no obvious farty noises, indicating to my old mind that there were no leaks.
Or do I put in a new, activated charcoal pollen filter. I don't think that it has been changed in the last 50k miles (80k)on the clock now...)
Link to comment
I have seen diesel or exhaust fumes in many cars
Exhaust fumes into cabin
Flexi pipe on downpipe or DPF
Bad Downpipe/DPF connection onto turbo/manifold
Exhaust manifold itself cracked/loose
EGR piping/seal leaking
Fuel smell into cabin
Fuel filter assembly top
Injectors underneath engine cover
Fuel lines/clips
Get a good torch in there and have a really good look
Failing that get it up on a ramp, undertrays off and look
A smoke test will help with manifold and exhaust issues
A leak should be quite obvious if you are smelling it
Edited by Turkeythighs
Link to comment
  • 4 months later...
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
