Mk1 Fabia Parts - EGR valve, strut brace, engine cover, pipercross, RCD200 radio,
hutchysrs50
Recommended Posts
Having a clear out of parts so here's the list.
Collection Is fine, From Newcastle.
Egr valve - £15 + £5 p&p
Have three of these, two are cleaned, come with clips for boost pipes £15 each
Front brace - £20 + £16 p&p
Bought it from eBay so is an eBay special jobbie! Cost me £40. Just taken it out the box to test fit and it's not the best on a Vrs, it catches the airbox and is tight up against the ECU, so lowering price.
Engine cover - £10 + £8 p&p
Standard engine cover but the gloss black bit has been painted green.
Pipercross air filter - £10 + £5 p&p
Seen better days, needs cleaning.
Pipe from turbo to egr valve - £5 + £5 p&p
Got two of these, both worked fine on removal
Turbo intake pipe reducer - £10 + £5 p&p
RCD200 radio & loom £30 + £16 p&p
Was removed from a newish VW transporter, has no code with it, but had a four digit code on the side which I tried twice and took back out, so will need to be left on for an hour before entering the correct code I believe?
Centre caps x 3 - £10 + £5 p&p
They came with my VW Montreal alloy wheels, but they got refurbished so weren't needed.
Turbo intake pipe from airbox - £10 + £5 p&p
Standard pipe removed from a 2005 vrs.
Pd130 KKK Turbo spares - £40 + £20 p&p
Got a standard turbo from a 2005 Fabia Vrs ASZ engine code. Failed due to something hitting the impeller and causing it to fold in. No play in the bearings however. Damaged compressor wheel has been removed as seen in picture.
Standard SMIC spares - £10 + £12 p&p
Got a standard intercooler from a Vrs, has a small hole at the front from the cold air feed rubbing its way through.
Link to comment
Share on other sites
Believe it's all fine, nice and tight in the metal part of the pipework but not sure about the intercooler side as I don't have it.
I'll remove it and take close up pictures of the lugs and seals, comes with the clip as well. How does £10 posted sound?
Link to comment
Hmmm think it's wider then 120cm or at least total wider than 225cm.
https://www.myhermes.co.uk/RWD/help/parcel-size.html#helppage
Failing that parcel force I suppose, will check now but probably about £30!
Parcel force
Delivery: Guaranteed 2 working days
Compensation: Up to £100
Tracking: Tracked
Price: £16.40 †
Maximum parcel length is 1.5m. Maximum length and girth combined is 3.0m
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
