Replacing Cassette Player with CD Player From Later Model?
Recommended Posts
Can it be done? Is it a straight swap, or are there extra looms, amps, or dashboard trim etc needed? I'm assuming it's the "Symphony" ones that fit,
I'm looking to upgrade to a CD player, but keep the standard look. There doesn't seem to be a single aftermarket stereo in the world that wasn't designed by a 12 year old with a bucket full of LEDs and LSD.
Mine is a 2001 Fabia with the MS402 cassette stereo installed.
Oh yes, and my car didn't come with a code - do I need one, or is the code stored in the radio, or does it accept any radio?
Edited by wiredsoftware
Link to comment
Share on other sites
Your old radio doesn't need a code perhaps but your new one might so be careful when parting with money.
If it were me I would want to use an external player - probably smartphone - so would mod the existing radio to take an input and fit a 3.5mm socket in one of the dummy switches above the radio. Think the MS402 can be modified if you are prepared to use a soldering iron. Google it...
Link to comment
Not sure that I can do that with the MS402 - there is no "CD" button on mine. The manual shows it can be an "AS" instead which is what I have, so looks like it doesn't support a CD changer which the Connects2 would use as the input channel. Assuming that I could get a Symphony CD player, I'd probably add the Connects2 AUX as well at some point, it's a nice subtle mod.
Link to comment
I did mention soldering...
http://hacks.ostserver.co.uk/2012/01/car-audio-skoda-ms402-aux-in-retrofit.html
If you planning to replace it you don't have a lot to lose.
Thanks for the link - I'm not clear from that how you activate the new aux input - do you have to put a (blank?) tape in the deck or something? How would it pick up to turn off the radio output? If I can figure that out I may well do this.
Link to comment
Reasonable questions but I don't have the answers  I'm afraid.
Wouldn't cost a lot to get an old lead with 2x screened wires to a 3.5mm plug e.g. from an old pair of earphones, and solder as indicated - suck it and see.
Link to comment
Thanks for all your info. Just been out to look at taking out the radio, and I've noticed that the GEO, AUD, AS, and 1-4 buttons don't work, so looks like this unit is only fit for scrap really, it's pretty much stuck on one station (radio 4)!
So I'm on the lookout for a Symphony CD unit (if it fits) or an aftermarket one I guess :(
Link to comment
I've just upgraded my brothers Fabia for him with a Symphony. They do slot straight in, perfect factory look... they are all over ebay with prices from £20 to over £100. If the one you buy doesn't come with its code, allow £10 to get this from a guy, also on ebay who works at a Skoda dealership and sells the codes!
Edited by favguy
Link to comment
Thanks, had a look over eBay, cheapest is about £50 inc. P&P with code, will see if one pops up a little cheaper for a couple of weeks.
Great to know it slots straight in.
Link to comment
For info I fitted a single din symphony from an Octavia mk1 and a CD multi changed to our old fabia. Slotted in fine with no issues but did need the top blanking trim for the dash.
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
