VCDS options on Superb III
Recommended Posts
Can the intermittent speed on the lowest wiper option be adjusted by vcds? When on auto, I find that it activates too soon and is causing noise when drawing across the windscreen as there isn't enough moisture on the screen. I came from a 2009 octavia which had a much longer time delay. I know the speed of the car is taken into play but I'm comparing it to the normal speeds I did with the octavia.
Can this be done? Any takers?
Link to comment
Share on other sites
Not that I am aware of.
Doesn't changing sensitivity with button on wipers stalk work for you?
Edited by mtl
Link to comment
Yes, my car has Kessy. Why?
Because only on cars with Kessy you can also close the boot, on cars without it you cannot close it via remote control...
Link to comment
Also on MY2016?
Link to comment
Also on MY2016?
Mine is MY2016  with Kessy  and i can open and close the boot with remote but you need to be out of the car. it doesnt work if the key fob is in the car.
Link to comment
Definitely not. Which vcds version are you using?
With VCDS no. I presume you have Kessy, right?
I have just download the latest 17.1.0 but i havent tried on the car yet. I was using 16.8.0  i think  when i checked last time.
Link to comment
That's the problem. It's too sensitive or activates too soon, which ever way you want to describe it. Thanks anyhow mtl.
Link to comment
Even if you have it on the most left setting?
Yes. I have it on the slowest setting (all the way to the left) and it's operating with barely noticeable moisture hitting the windscreen, causing the wipers to start screeching across the windscreen. As a result I don't have it on auto any longer and flick the stalk down as and when needed unless in real rain when it's put on fully. The way it's going I'll be replacing the wiper blades a lot sooner than expected.
Edited by BennyS3
Link to comment
But if you have VCP you can change that, so cars without KESSY can close the boot via the remote as well.
Link to comment
Just a note of interest, earlier in this thread I read that the keyless entry system does not work on proximity and could not be switched on via VCDs. I have seen a advert for the new Seat SUV where one of the cars selling points is that it unlocks as you approach and locks as you move away. Just wondered if Seat & Skoda as same family would be using same keyless system ?
Link to comment
Correct, though I think that it is not so straightforward for newer models...
It could be that this is connected with ''half-generation'' change, etc. new Ateca, Kodiaq, facelift Octavia 3, facelift Golf 7. If it is so then also Superb will get it with MY change or facelift.
Can you link the add?
Link to comment
Ok, not sure how this is related to my original question, maybe I didn't formulate it clearly.
I would like to a avoid a situation where the boot would open by unintentional long press of the middle (boot) button on the remote. I have it always in my jeans pocket. It's one thing that the car doors are unlocked unintentionally (and they will anyway soon lock again if no door is opened), but to get to the car after a day and that it waits for you with the open boot, in the rain, well, scary. I also have virtual pedal so really no use for this remote function, just a real possibility for some big problem.
I'd also have no problem of disabling the boot button on the remote completely, if that would be possible via VCDS.
If not possible to disable it using VCDS, do you think it can be disabled by a dealer?
Link to comment
This has been a problem for me on several occasions too! It's not just you who looks out of the house window to find the boot wide open in the rain! With the handle-touch locking and unlocking, it isn't really necessary to use any of the buttons on the remote - I'm thinking of getting a small (matchbox sized) box to put the key in. In the mean time I've taken to keeping it in a breast pocket if I have one.
Link to comment
mtl
http://www.seat.co.uk/new-cars/new-ateca/technology.html
try this, scroll down page, it definitely shows proximity as beginning the reason for the lock / unlock sequence being initiated.
Link to comment
mtl
My MY2016 Superb doesn't exactly unlock the car as you approach, but when you grip the door handle with the key in your pocket it unlocks. Similarly if you touch the right bit of the handle after you get out and close the door, the car locks. So no need to get the key out of your pocket, and since you need to grip the handle to open the door anyway I don't really see any advantage of the car unlocking itself as you approach. Yes I do have to touch the door handle to lock but to be honest I think I prefer that to having it lock automatically - you don't always want to lock the car when you walk away with the key.
Link to comment
I have a photo of my sensors behind rear mirror
http://prntscr.com/dx8qvf
So I guess I dont have front facing camera, can anybody know is it possible to install this camera later in few years?
It does not.
y guess is that it would be better to replace the car for a car with camera. Maybe you could get away with it if you would get all the parts from car in accident, but even then there are not a lot of people that would manage to do this. You would also have to change front window, rear-view mirror mount, maybe some other electronics, camera needs to be calibrated, etc.
mtl
Interesting, it definitely says proximity:
KEYLESS ENTER & GO
With this feature you no longer have to worry about taking your keys out of your pocket to unlock your car. Simply approach the vehicle and it will unlock depending on proximity.
I will have to check with my local dealer if this is true or just another marketing bull**** :).
In my opinion Renault has this system perfect. It automatically locks the car when you are cca. 2m away, just what I would need.
Link to comment
Mine is the same, it can smell the moisture too with the humidity sensor i think.  hahaha  but so far it didnt let me down, if it start wiping and i am like where is the rain, then the drops get bigger and bigger .  Taiwan is very humidit.
Link to comment
It does not.
Then I am fu**ed :(, tenx for the info :)
Link to comment
Not everyone. The J and M module not yet already busy with those modules and VCP
Link to comment
Hey guys, i need help with my MY2017.
The car is factory equipped with Traffic Signs Recognition, Blind Spot Detect. I've successfully added the lane assist,
but when i've tried to add the light assist, VCDS 17.1.1 did not recognize the long coding of "09-Cent. Elect".
Here is a quick scan of the central electronic module
Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-V2.clb
   Part No SW: 5Q0 937 084 CG    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H34 0236
   Serial number: 02001631501034
   Coding: 000000000000000000000000000000000000000000000000000000000000
   Shop #: WSC 33361 790 00156
   ASAM Dataset: EV_BCMMQB 017001
   ROD: EV_BCMBOSCH_017.rod
   VCID: 7FA0DC86BB7D4CE1D6-802A
Also the long coding of the A5 Camera module is completely different form the MY2016  cars.
Address A5: Frt Sens. Drv. Assist (R242)       Labels: 3Q0-980-65X-A5.clb
   Part No SW: 3Q0 980 654 G    HW: 3Q0 980 654
   Component: MQB_B_MFK     H06 0231
   Serial number: 20111612P20126
   Coding: 0204080200000401002223508040A80010000E100000
   Shop #: WSC 33361 790 00158
   ASAM Dataset: EV_MFKBoschMQBB 001001
   ROD: EV_MFKBoschMQBB.rod
   VCID: 3B6464FA8B91E48536-806E
I guest that we have to wait for a while in order to see the long coding of this part no: 5Q0 937 084 CG
Any suggestions ?
Edited by remix
Link to comment
Does anybody know if it's possible to change the XDS diff to 'Strong' on the Sportlines (not sure what other models have the diff)?
I had this done on my Leon and you can tell a difference, would like to do it on my Sportline if possible.
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
