VCDS can't enable Driver Alert System
Recommended Posts
Made a couple of VCDS adaptions tonight but afterwards it looks like I have a new option for "Driver Alert System" which I cannot enable.
Couple of questions:
1. Am I right that this option does not appear as standard? (to turn on I mean)
2. Is this the fatigue sensor and this is standard on vrs but I don't think there is an option to turn it off.
Link to comment
Share on other sites
it's enabled on mine (an SEL) and the vRS is supposedly an SE with extra kit added. Basically the vRS is an SE with added sporty stuff and the SEL is an SEL with added non sporty stuff. Both should have it.
Looking on here the fatigue sensor can't be enabled or disabled by VCDS and I know we didn't touch anything remotely like fatigue assist.
In case it helps here is what we enabled
  • Enabling cornering fogs with additional settings for vRS
  • Enabling laptimer in the maxidot
  • Enabling Traffic Sign Recognition on models with Lane Assist
  • Enabling passenger mirror dip on selecting reverse
  • DRLs flash alternately with indicating
  • Enabling High Beam Assist (intelligent Light Assistant) on models with the Lane Assist Camera
and this was the scan at the start
Monday,31,August,2015,20:30:26:14512
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 15.7.0.1 (x64)
Data version: 20150729
www.Ross-Tech.com
VIN: TMBKK7NE6G0038651   License Plate:
Chassis Type: NE (5Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 42 44 52 55 5F A5 A9
VIN: TMBKK7NE6G0038651   Mileage: 1499km-931miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
A9-Struct. Borne Sound -- Status: OK 0000
Address 01: Engine (J623-CUNA)       Labels: 04L-907-309-V1.clb
   Part No SW: 04L 906 026 BR    HW: 04L 907 309 R
   Component: R4 2,0L EDC   H21 1540
   Revision: B5H21---
   Coding: 01190032032501080000
   Shop #: WSC 73430 031 00000
   ASAM Dataset: EV_ECM20TDI01104L906026BR 002003
   ROD: EV_ECM20TDI01104L906026BR_SK37.rod
   VCID: 7BFEFEA9F2DDD0E603-802E
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-ESP-V1.clb
   Part No SW: 3Q0 907 379 T    HW: 3Q0 907 379 C
   Component: ESC           H32 0393
   Revision: 00000000    Serial number: 61705000000535
   Coding: 1C07939154230974007D060541C42938C92A9000608294F410635072C009
   Shop #: WSC 73430 031 00063
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 034033
   ROD: EV_Brake1UDSContiMK100ESP_SK37.rod
   VCID: 4B9E6E69E2FDA066F3-801E
Address 08: Auto HVAC (J255)       Labels: 5G0-907-044.clb
   Part No SW: 5E0 907 044 Q    HW: 5E0 907 044 Q
   Component: Climatronic   H04 1002
   Revision: 00001K07
   Coding: 02110104000100011005000000101000
   ASAM Dataset: EV_ACClimaBHBVW37X 004131
   ROD: EV_ACClimaBHBVW37X_SK37.rod
   VCID: 336E16899A0DD8A69B-8066
Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-HV1.clb
   Part No SW: 5Q0 937 086 AK    HW: 5Q0 937 086 AK
   Component: BCM PQ37BOSCH 028 0162
   Revision: --------    Serial number: 86581106150752
   Coding: 0F500A42C24722FB07A04082B10C07280000000000000000000000000000
   Shop #: WSC 73430 790 00000
   ASAM Dataset: EV_BodyContrModul1UDSBosc 015002
   ROD: EV_BCMBOSCH_AU37.rod
   VCID: 030E86498A2DA8264B-8056
   Slave 1:
   Subsystem 1 - Part No SW: 5E2 955 119     HW: 5E2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS371 150530  041 0570
   Serial number:         150604114938
   Coding: 065DDD
   Slave 2:
   Subsystem 2 - Part No SW: 5Q0 955 547 A    HW: 5Q0 955 547 A  Labels: 5Q0-955-547.CLB
   Component: RLHS  037 0059
   Serial number: S5Y15M06D25H23M29S50
   Coding: 00885D
   Subsystem 3 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
   Component: Sensor, DWA  005 0315
   Serial number: 000000000ZY1505106VS
   Subsystem 4 - Part No SW: 5Q0 951 605     HW: 5Q0 951 605
   Component: Sirene, DWA  004 0311
   Serial number: 00000000000032517038
   Subsystem 5 - Part No SW: 5E9 959 591 B    HW: 6R0 959 591 D
   Component: J245 PS24.402  H03 0004
   Serial number: 0000FST000CDLU400000
   Coding: 991800
   Subsystem 6 - Part No SW: 5E9 959 591 C    HW: 8V3 959 591 A
   Component: J394 PS24.402  H03 0004
   Serial number: 0000FST000CXZNV00000
   Coding: 991800
1 Fault Found:
527872 - Transport Mode Active
          U1105 00 [008] - -
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-298.clb
   Part No SW: 5Q0 919 298 K    HW: 5Q0 919 298
   Component: PARKHILFE PLA H12 0054
   Revision: --------    Serial number: 39491514904368
   Coding: 0131061041
   Shop #: WSC 73430 790 00063
   ASAM Dataset: EV_EPHVA2CAU3700000 003021
   ROD: EV_EPHVA2CAU3700000_SK37.rod
   VCID: 47965259FE954406D7-8012
Address 13: Auto Dist. Reg (J428)       Labels: 5Q0-907-572.clb
   Part No SW: 5Q0 907 572 F    HW: 5Q0 907 572 F
   Component: ACC Bosch MQB H05 0400
   Serial number: 20051503210183
   Coding: 00000600FE0339
   ASAM Dataset: EV_ACCMRRBoschVW372 001016
   ROD: EV_ACCMRRBoschVW372_AU37.rod
   VCID: 3A703BADBD6729EE58-806E
Address 15: Airbags (J234)       Labels: 5Q0-959-655.clb
   Part No SW: 3Q0 959 655 AS    HW: 3Q0 959 655 AS
   Component: Airbag VW20   013 0200
   Revision: --------    Serial number: 003SQPBSR4P5
   Coding: 98CCC000000000005C5400CC008800000065
   ASAM Dataset: EV_AirbaVW20TS6VW48X 001116
   ROD: EV_AirbaVW20TS6VW48X_SK37.rod
   VCID: 0F26BA79D665DC46DF-805A
   Crash sensor for side airbag; driver side:
   Subsystem 1 - Part No SW: -----------    HW: 454 001 306 15
   Component: SideSensor_Df  008 0887
   Serial number: 3576U000000A3810051-
   Coding: 2D2D2D
   Crash sensor for side airbag; front passenger side:
   Subsystem 2 - Part No SW: -----------    HW: 454 001 006 15
   Component: SideSensor_Pf  008 0887
   Serial number: 3586U000000A9121E418
   Coding: 2D2D2D
   Crash sensor for side airbag; rear; driver side:
   Subsystem 3 - Part No SW: -----------    HW: 454 801 406 15
   Component: SideSensor_Dr  301 0148
   Serial number: 3516R8D5A32070000004
   Coding: 2D2D2D
   Crash sensor for side airbag; rear; passenger side:
   Subsystem 4 - Part No SW: -----------    HW: 454 802 006 15
   Component: SideSensor_Pr  301 0148
   Serial number: 3526RA4003B07000000Z
   Coding: 2D2D2D
   Crash sensor for front airbag; driver side:
   Subsystem 5 - Part No SW: -----------    HW: 454 801 605 15
   Component: FrontSensor_D  114 0149
   Serial number: 3556V37BC5706000000F
   Coding: 2D2D2D
Address 16: Steering wheel (J524)       Labels: 5Q0-953-549.clb
   Part No SW: 5Q0 953 521 M    HW: 5Q0 953 569 A
   Component: Lenks.Modul   075 0195
   Revision: FF033033    Serial number: 20150628400195
   Coding: 1400
   ASAM Dataset: EV_SMLSVALEOMQB 001015
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3C7C3DB5B75317DE4A-8068
Address 17: Instruments (J285)       Labels: 5G0-920-XXX-17.clb
   Part No SW: 5E0 920 957 B    HW: 5E0 920 957 B
   Component: KOMBI         311 6420
   Coding: 27A509006990A600018A6A031000000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009046
   ROD: EV_DashBoardVDDMQBAB_AU37.rod
   VCID: 2C5C0DF54733875EDA-8078
Address 19: CAN Gateway (J533)       Labels: 5Q0-907-530-V1.clb
   Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1223
   Revision: --------    Serial number: 0003658732
   Coding: 030100040F087300EB00026A080F00010001050000000000000000000000
   ASAM Dataset: EV_GatewLear 013020
   ROD: EV_GatewLear.rod
   VCID: 75EAE891D4F9869675-8020
   Alternator:
   Multifunction unit control module:
   Subsystem 2 - Part No SW: 3V0 919 719 A    HW: 3V0 919 719 A
   Component: E221__MFL-PR6  H02 0150
   Serial number: 000000000B1837100615
   Battery Monitoring Control Module:
   Subsystem 3 - Part No SW: 5Q0 915 181 F    HW: 5Q0 915 181 F
   Component: J367-BDM  H08 0223
   Serial number: 62166N32514291237366
Address 42: Door Elect, Driver (J386)       Labels: None
   Part No SW: 5Q4 959 393 E    HW: 5Q4 959 393 B
   Component: TSG FS        010 0031
   Serial number: 0000155914584
   Coding: 001C00208001040000001100
   ASAM Dataset: EV_DCUDriveSideEWMAXCONT 006001
   ROD: EV_DCUDriveSideEWMAXCONT_SK37.rod
   VCID: 458A5851C499561625-8010
   Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A
   Component: FOND_FHSG_DRV  005 0005
   Serial number: 00000000000006442291
   Coding: 1D0200
Address 44: Steering Assist (J500)       Labels: 5Q0-909-144.clb
   Part No SW: 3Q0 909 144 H    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5061
   Coding: 9303
   ASAM Dataset: EV_SteerAssisMQB 012140
   ROD: EV_SteerAssisMQB.rod
   VCID: 377622998E753486A7-8062
Address 52: Door Elect, Pass. (J387)       Labels: None
   Part No SW: 5Q4 959 392 E    HW: 5Q4 959 392 B
   Component: TSG BFS       010 0031
   Serial number: 0000156384728
   ASAM Dataset: EV_DCUPasseSideEWMAXCONT 006001
   ROD: EV_DCUPasseSideEWMAXCONT_SK37.rod
   VCID: 448C4555CFA36F1E32-8010
   Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A
   Component: FOND_FHSG_PSG  005 0005
   Serial number: 00000000000006544539
   Coding: 050200
Address 55: Headlight Range (J745)       Labels: 7P6-907-357.clb
   Part No SW: 7P6 907 357 D    HW: 7P6 907 357 A
   Component: AFS-ECU       H07 0090
   Revision: --------    Serial number: --------------
   Coding: 03DE00003F000000
   ASAM Dataset: EV_HeadlRegulVWAFSMQB 001120
   ROD: EV_HeadlRegulVWAFS_SE26.rod
   VCID: 40844945DBBB733E16-8014
   Subsystem 1 - Part No SW: 1T0 941 329 B    HW: 1T0 941 329 B  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H06 0009
   Coding: 3E0000
   Subsystem 2 - Part No SW: 1T0 941 329 B    HW: 1T0 941 329 B  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H06 0009
   Coding: 3E0000
Address 5F: Information Electr. (J794)       Labels: None
   Part No SW: 5Q0 035 874 A    HW: 5Q0 035 874 A
   Component: MU-S-ND-ER    H24 0241
   Serial number: SKZAZ2R8673093
   Coding: 03735201FF00000011111201008800002F0201C601200100C6
   ASAM Dataset: EV_MUStd4CTSAT 001022
   ROD: EV_MUStd4CTSAT_SE25.rod
   VCID: 3260138D6517D1AE90-8066
   Media Player Position 1:
   Subsystem 1 - Part No SW: 5E0 919 605 J    HW: 5E0 919 605 J
   Component: ABT_Std-2_Nav  H41 1028
   Serial number: SKZ8Z9RBT0081S
   Engine Control Module 2:
   Subsystem 2 - Part No SW: 5L0 051 236 E    HW: -----------
   Component: ECE 2015/16  --- 0430
   Serial number: --------------------
Address A5: Frt Sens. Drv. Assist (R242)       Labels: 5Q0-980-653.clb
   Part No SW: 5Q0 980 653 G    HW: 5Q0 980 653
   Component: MQB_MFK       H06 0060
   Serial number: 10000377427
   Coding: 0100000001030306000400000100010100
   ASAM Dataset: EV_MFKBoschAU370 001001
   ROD: EV_MFKBoschAU370_AU37.rod
Address A9: Struct. Borne Sound (J869)       Labels: 4H0-907-159.clb
   Part No SW: 5E0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0001
   Serial number: 150521200404
   ASAM Dataset: EV_SoundActuaGen2AU64X 003010
   ROD: EV_SoundActuaGen2AU64X.rod
   VCID: 69D2B4E188415276E1-803C
End-------------------------(Elapsed Time: 04:08)--------------------------
Link to comment
Must have turned it off somewhere in our vcds codings. Did notice lots of different options appearing on the mib when making the changes.
Options to enable mirror folding stuff like that when I don't have folding mirrors.
Link to comment
Its supposed to take data from the steering angle sensor and ESC system and using some algorithm determines when it thinks you are tired. It no doubt factors time into that equation too.
I've got it on two cars and its not gone off once in circa. 31.5k combined miles.
  • Like 2
Link to comment
Mine never comes on when round town or on the twisties. Nearly always on the A1 just before Leaming Bar Maccy D's!!!
Thought they had done a deal with VAG and had some GPS thing that went off when you approached :D
  • Like 1
Link to comment
Haha quality...basically the coffee cup symbol should be amended to a burger on your car mate :-)
  • Like 1
Link to comment
Guest Cossiecol
Mmm must have been an adaption change that disabled it. Any ideas what option would disable it? AndyVee around?!
 Take it back to your guy H and get him to sort it. Next time take it to the garage I suggested ;)
Link to comment
Have you got the log that was kept open during all of the coding session so you have a record of all the changes?
What version of VCDS was being used?
If you have the log, PM it to me and I'll have a scan through. If you haven't got the log, PM me the Coding.log file from the VCDS debug folder and let me know the date and time the coding session took place.
A tip for everyone - KEEP THE LOG FILE OPEN!!!!
  • Like 2
Link to comment
this is the coding session Andy
we did cornering fogs, HBA, DRLs to flash with indicators, traffic sign recognition and mirror dip
High Beam Assist
Address 09:5Q0 937 086 AK recoded (ADP-(2)-Assistance light functions-Menuesteuerung Fernlichtassistent) from Not Present  to present   Monday,31,August,2015,20:43:25:14512
Address 09:5Q0 937 086 AK recoded (Long Coding) from 0F500A42C24722FB07A04082B10C07280000000000000000000000000000 to 0F500B42C24722FB07A04082B10C07280000000000000000000000000000  (73430/790/00000)  Monday,31,August,2015,20:44:00:14512
Address 09:5Q0 937 086 AK recoded (ADP-(6)-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung) from Not Present  to present   Monday,31,August,2015,21:02:12:14512
Address 09:5Q0 937 086 AK recoded (Long Coding) from 0F500B42C24722FB07A04082B10C07280000000000000000000000000000 to 0F500A42C24722FB07A04082B10C07280000000000000000000000000000  (73430/790/12345)  Monday,31,August,2015,21:09:05:14512
LED blink when indicating
Address 09:5Q0 937 086 AK recoded (ADP-(16)-Leuchte2SL VLB10-Lichtfunktion G 2) from not active  to Blinken links Hellphase   Monday,31,August,2015,21:16:12:14512
Address 09:5Q0 937 086 AK recoded (ADP-(18)-Leuchte2SL VLB10-Dimmwert GH 2) from 0  to 25   Monday,31,August,2015,21:16:54:14512
Address 09:5Q0 937 086 AK recoded (ADP-(19)-Leuchte2SL VLB10-Dimming Direction GH 2) from maximize  to minimize   Monday,31,August,2015,21:17:23:14512
Address 09:5Q0 937 086 AK recoded (ADP-(16)-Leuchte3SL VRB21-Lichtfunktion G 3) from not active  to Blinken rechts Hellphase   Monday,31,August,2015,21:18:51:14512
Address 09:5Q0 937 086 AK recoded (ADP-(18)-Leuchte3SL VRB21-Dimmwert GH 3) from 0  to 25   Monday,31,August,2015,21:19:22:14512
Address 09:5Q0 937 086 AK recoded (ADP-(19)-Leuchte3SL VRB21-Dimming Direction GH 3) from maximize  to minimize   Monday,31,August,2015,21:19:54:14512
Address 09:5Q0 937 086 AK recoded (Long Coding) from 0F500A42C24722FB07A04082B10C07280000000000000000000000000000 to 0F500B42C24722FB07A04082B10C07280000000000000000000000000000  (73430/790/12345)  Monday,31,August,2015,21:26:20:14512
Address A5:5Q0 980 653 G recoded (Long Coding) from 0100000001030306000400000100010100 to 0100020001030306000400000100010100  (73430/790/00000)  Monday,31,August,2015,21:28:53:14512
Address A5:5Q0 980 653 G recoded (Long Coding) from 0100020001030306000400000100010100 to 0100010001030306000400000100010100  (73430/790/12345)  Monday,31,August,2015,21:29:29:14512
Address 5F:5Q0 035 874 A recoded (ADP-(63)-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21) from not activated  to activated   Monday,31,August,2015,21:37:16:14512
Address 5F:5Q0 035 874 A recoded (ADP-(63)-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21) from not activated  to activated   Monday,31,August,2015,21:37:38:14512
Address 5F:5Q0 035 874 A recoded (ADP-(151)-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification) from not activated  to activated   Monday,31,August,2015,21:40:05:14512
Address A5:5Q0 980 653 G recoded (ADP-Display end of speed limit symbol) from not activated  to activated   Monday,31,August,2015,21:41:37:14512
Address 17:5E0 920 957 B recoded (Long Coding) from 27A509006990A600018A6A031000000000000000 to 27A509006994A600018A6A031000000000000000  (73430/031/00000)  Monday,31,August,2015,21:42:23:14512
Address A5:5Q0 980 653 G recoded (Long Coding) from 0100010001030306000400000100010100 to 0101010001030306000400000100010100  (73430/790/12345)  Monday,31,August,2015,21:43:04:14512
Address 5F:5Q0 035 874 A recoded (ADP-(151)-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification) from not activated  to activated   Monday,31,August,2015,21:44:24:14512
Address 5F:5Q0 035 874 A recoded (ADP-(63)-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21) from not activated  to activated   Monday,31,August,2015,21:45:10:14512
Left wing mirror dip
Address 09:5Q0 937 086 AK recoded (ADP-(17)-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt) from not active  to active   Monday,31,August,2015,21:55:12:14512
Address 09:5Q0 937 086 AK recoded (ADP-(22)-Access control 2-Menuesteuerung Spiegelabsenkung) from not active  to active   Monday,31,August,2015,21:56:54:14512
Address 09:5Q0 937 086 AK recoded (ADP-(22)-Access control 2-Menuesteuerung Spiegelabsenkung) from not active  to active   Monday,31,August,2015,21:57:22:14512
Address 52:5Q4 959 392 E recoded (Long Coding) from 001C00208001040000001100 to 001C00208C01040000001100  (73430/790/00000)  Monday,31,August,2015,21:58:21:14512
Address 09:5Q0 937 086 AK recoded (ADP-(22)-Access control 2-Menuesteuerung Spiegelabsenkung) from not active  to active   Monday,31,August,2015,22:00:37:14512
Address 09:5Q0 937 086 AK recoded (ADP-(22)-Access control 2-Menuesteuerung Spiegelabsenkung) from not active  to active   Monday,31,August,2015,22:01:20:14512
Address 17:5E0 920 957 B recoded (Long Coding) from 27A509006994A600018A6A031000000000000000 to 27AD09006994A600018A6A031000000000000000  (73430/031/12345)  Monday,31,August,2015,22:04:09:14512
  • Like 1
Link to comment
Ok stranger and stranger! Myself and Domhnall have just finished recoding my car, reverting all the changes we made and now the only options I have on my driver assistance settings are:
Front Assist (with options)
Lane assist (with options)
Just 2 sets, nothing at all for Driver Activity Sensor. (before any adaptions I was sure that this was the case) Does that mean my car has no fatigue sensor??!
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
