loosing coolant! PLEASE HELP
hogan1996
Recommended Posts
And just as likely to be a Perished Hose, loose hose clip, corroding radiator, cracked reservoir (filler bottle.)
Leak at the Water Pump, Needs a new Radiator cap etc etc
So do not put off checking out why the coolant is dropping before the cold weather comes and you need a good strength of coolant (anti freeze) in the System.
(do not fill to the Max, it can find its own level.)
So how long have you had the car,
when did it start to lose coolant,
& how much does it lose or how quickly does it drop?
Link to comment
Share on other sites
Hi, my 2005 (55) Fabia runs well and doesnt miss a beat but it looses coolant, the oil cap is clean with no gunk on...
wondered if anyone could help me?
Get your car booked in for a pressure test. Or diy.
I had same fears with mine. Had a full service month ago which included waterpump change.
Then coolant light kept flashing.
Turns out the expansion tank had a slight crack . Pressuretest only cost me a tenner (friendly mechanic)
Fitted new tank and cap in half hr total cost £18. Job done and cured.
Id get it checked asap
Edited by vzo25
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
