Hissing noise
Recommended Posts
Mine does the same think I've been told it's nothing to worry about.
Its the vaccum system fed (sucked) from brake servo "T" off into pipes into a pipe system that operates EGR, Variable Vanes and anti shudder valve using solenoids with a vacuum resevoir
It can spring a leak in the flexible or fixed pipes - one of my fixed pipes rubbed through because of vibration - easy fix - showed up as EGR fault(it was fine) and engine shuddered on turn off
To ensure all well make sure anti shudder valve is operating - this will show vacuum operating. With the bonnet lifted looking from front towards windscreen this is the vlave thats visible to the left of the engine cover. The plunger should operate as you turn the engine off - oh and of course the engine should stop without a shudder
Link to comment
Share on other sites
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
