Buying standard dog bone bushes?
Recommended Posts
Hi all,
I have fitted poly bushes on my dogbone(Rear engine mount) and it has a really annoying vibration through the dash and steering wheel everytime I pull off from standstill.  I have done over 500 miles easy with it now and slackened the nut a bit but it's still horrible to drive with.
Unfortunately I disposed of my old rubber bushes.  Where can I get new standard OEM bushes for the dogbone without having to replace the entire part?  I tried ebay but struggled to find anything.
Cheers,
Samuel
Link to comment
Share on other sites
Main dealers are probably going to be the place or TPS centre. There's a guy on facebook called Sean Kemp he works for TPS ask him if they do them?
Link to comment
Just grab a used dog bone off eBay for a tenner or something. You'll easily make your money back by flogging your polybushed dog bone. I wouldn't be without my Vibra-Technics dog bone bushes, despite the minor extra cabin noise and vibration; the amount the engine moves with soft bushes terrifies me.
Link to comment
It just happens if I try to pull off from standstill normally like a normal driver.  To reduce the dash and steering vibrations I have to give the car more gas than normal as I`m lifting the clutch, which isn`t good for the clutch I`m sure.
I also question whether having reduced movement with this stiffer poly bush is causing damage elsewhere, in the transmission or to the other mounts..
Edited by sammyhale30
Link to comment
Should have bought the tdi bushes they are softer because of the extra vibrations of a diesel
Link to comment
True that. The vibration will get better though, eventually. Depends if you can stand it for long enough.
Link to comment
I might try backing the nut off.  That's my first plan I reckon before I go back to standard.  I did remember that when I put the polybush ones in they were really tight before I actually put the nut on.  I had to put the dogbone in a vice to pull it together a bit so that I could actually start the nut going on the thread.
Link to comment
How many miles have you done with them in as they do settle down just take abit of time,
They are horrid to start with but after a 1000 miles you won't nootice their there
Link to comment
The bolt holding the whole dog bone together only needs to be lightly done up, around 15NM or so. The others I think are stretch bolts as the torque settings comprise a torque and then an angle. I bought new subframe and gearbox bolts for the dog bone and did them up to whatever the Haynes manual said. Google says 20NM plus a quarter turn and 40NM plus a quarter turn for the subframe and gearbox bolts, respectively.
Link to comment
Thought so. They are stress bolts and should be renewed, although people don't always and not had problems. Is it a risk worth taking? Probably not...
Link to comment
Hasn't there been a few stories of people doing their cam belts, reusing the engine mount bolts, which are stretch bolts, and then finding their engine falling out because the bolts have let go? Sod that for the sake of a few quid for new bolts!
Link to comment
Exactly. Also worth considering those bolts will be under more stress with new polybushes in. Bolts like that are fairly critical (understatement)...
Link to comment
I also noticed that the engine side of the dog bone there is a black piece of metal that can be moved into different positions.  Is the position of this important at all?  I vaguely remember when I removed the mount the first time this black piece of metal was in a sort of 35 degree position.  Since I`ve put it back on its now pointing straight forward...
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
