How to remove the front undertray
muddyboots
Recommended Posts
While I was changing my gearbox oil the other day, I took a few photos to do a quick guide on removing the undertray.
This guide shows the undertray on a 2011 CR170 4x4, but I imagine it will apply to other models too.
It's pretty easy once you've got the car lifted up safely.
Tools required:
 - means of safely raising front of car
 - T25 torx bit
 - T45 torx bit
1) Raise the front of the car and support it safely. Either use ramps or a lift. or jack it up and use axle stands. Handbrake on firmly. Never ever work under a car that's just supported by a jack.
2) Remove the screws from the undertray, there are 11 in total.
First remove the 4 screws along each side, these require a T25 Torx bit to undo. These aren't very tight, you could do this with a Torx-head screwdriver; I used a Torx bit in my cordless drill for speed.
Next remove the 3 screws along the rear edge, these require a T45 Torx bit. These are a bit tighter than the others.
As you remove the last screw, support the undertray (it's not very heavy) then slide it rearwards; the front edge will then disengage from the car and it will come free.
Put the screws somewhere safe.
Er, and that's it!
Some photos:
The undertray, showing (most of!) the screw locations. There are 11 in total, a couple are slightly out of shot to the right.
With undertray removed:
The screws, and torx bit sizes required:
  • Like 1
Link to comment
Share on other sites
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
