Steering Wheel Buttons
DaveBee
Recommended Posts
Hi, this is my first post here after I picked up a 2009 Superb this morning.
I spent my lunch break in the car setting up all the toys using the steering wheel buttons and the display on the instrument cluster, but when I just got in it to drive home, none of the buttons seem to work any more.
I can use the scroll wheels to adjust the volume and scroll through options on the display, but if I press any of them (like the phone button, or the right hand scroll wheel to OK/Enter) nothing happens. Yikes!
Please tell me this is something simple that I'm doing wrong... it was working fine earlier.
Dave
Link to comment
Share on other sites
Dave
I once had this whilst my car was struggling to pair with a phone - just said "connecting"(even after turning ignition off and on again) - took ages to time out. It's been OK since and works with the same offending phone!
Try turning your mobile off (if you have bluetooth)
Edited by bigjohn
Link to comment
Thanks bigjohn, I just went out to the car and tried it without my phone, but it made no difference.
I paired my phone first thing at lunch time, then played with all the settings with no trouble at all.
It was later on, after work, that I noticed none of the push buttons on the steering wheel work at all suddenly. The scroll wheels do work, so I can adjust the volume of the radio, and scroll through the menus, I just can't select anything.
Link to comment
To clarify does that mean all buttons including pushing the scroll button in
Link to comment
Yeah, the scroll bars work for scrolling, but not pushing them..
Disturbed earth? Evidence of wheel been off recently?
Have you bought your car from a garage - if so you will have some sort of warranty
Link to comment
Does look as though the buttons can fail eventually(need firmer push beforehand)  - but I would be amazed if they suddenly failed on the same day
Link to comment
Hmm... OK. It came from a second hand car dealer, but I noticed a couple of things wrong, so it went to a VW specialist run by a friend of a friend for those items to be corrected, which is why I felt OK about buying it. I might ring them tomorrow.
Link to comment
Weird... Obviously I tried the buttons on my way into work this morning and they were not working.
Just been out now (lunch time) and everything works perfectly.
Annoyingly, I just booked it into our local VW specialist before I got up and went out!
Maybe they only work between the hours of 12 & 2?!
Edited by DaveBee
Link to comment
Sounds like its not the actual buttons themselves - they both don't break and fix themselves at the same time.
How many miles has it done? has it gone part time approaching retirement  :notme:  - says he not working tomorrow!  :clap:
Link to comment
I think it is something to do with the position of the wheel in relation to the connection of the earth as bigjohn suggested. On our MKI, the cruise buttons on the wheel can be completely inoperative, but by turning the wheel all the way to the left and to the right and bingo, all is well again. It's worth giving it a try? Edited by numskull
Link to comment
This might be off track, but you can't some change settings in the MFD (multi function display) when the car is moving/running. I thought I'd broken something too when I got the car and 'lost' the ability to change stuff while waiting at the traffic lights.
Link to comment
I can't change MFD  "settings" when moving but can when stationary (with stop/start engaged  or engine still running). Can always operate phone, onboard computer &ICE though
Link to comment
Yup, it's not possible to change any settings unless the car is stationary.
Link to comment
Cheers guys, I know you can't change a lot of the settings while you are moving, but this is everything. I can scroll through the MFD OK, but pushing the right scroll wheel does nothing. Same with the phone and back buttons. I had a couple of text messages today, and I could scroll between "Show" and whatever the other option is just fine, but pushing the scroll wheel did nothing. Again - it worked absolutely fine at lunchtime. I took the car out and went and parked up somewhere quiet to read through the manual and have a fiddle with stuff. Everything worked. I could scroll through and select every option I could think of on the instrument cluster.
Got back in the car after work and it worked for about 30 seconds, then nothing.
It's booked in Monday morning. The driver's heated seat doesn't work either, so they are looking at that too.
Link to comment
Sounds like CANBUS gremlins to me. Good luck with resolving this, and be sure to post a follow up, thanks.
Link to comment
Same thing here, it started with Bluetooth acting funny but was going through the menus fine...now it's stuck on pairing Bluetooth as I've reset to factory values...can it be faulty main board ? I had it replaced twice as my right indicator was constantly on...could it be the same module responsible for that ? I have a diagnostic cable cable...would it show anything if that module is malfunctioning ?
Link to comment
Mine is currently being looked at. I'll respond again when I know more.
Typically, the buttons were not working when I got in it this morning, but when I demonstrated it to the tech, they worked just fine.
Link to comment
  • 6 years later...
Did you manage to fix this? I've got a 2011 Octavia the right scroll wheel has stopped selecting things. Can scroll fine and the others work but it won't actually select anything to bring up another menu like the audio or nav. It's rather annoying. Been like this for a few days now
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
