How long does your airbag warning light stay on?
longedge
Recommended Posts
Shouldn't it switch off straight away? As in it comes on for a second when you switch the ignition on as a means to check the light is functioning.
I think they may talking about the passenger air bag light next to the Hazzards switch. You are correct the Air bag test light in the dash only stays on for a couple seconds.
Link to comment
Share on other sites
This is what my handbook says:
› Check that the [front passenger airbag] warning light  lights up
after the ignition is switched on.
The [front passenger airbag ] warning light goes out 65 seconds after the key switch status has
changed or after the ignition is switched on.
Jim
Edited by muddyjim
Link to comment
I asked to see if there was a consensus. Mine isn't predictable, in terms of distance it's anything from the first few hundred yards from home up to a mile - probably anything between 20-60 secs. but I suppose that as long as it goes out then al is well. Must hold my hand up and admit I hadn't read the manual :blush:
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
