Retrofit aero wipers
Mcinvrs
Recommended Posts
I fitted these ones:
VAG Part Nos:
Drivers side blade: 1J2 955 426B
Passenger blade: 1J2 955 425B
Drivers arm: 1J2 955409 D
Passenger arm: 1J2 955 410D
This.
There are retrofit options out there, Bosch and Valeo are the best of them. All miss a patch on the passengers side and distort a bit at speed but they'll do the job - you can get a shorter one for the passenger side or cut it down to avoid the above but then it covers a much smaller area.
I persevered with a few different ones before calling it a day and doing it properly.
Replacing the arms and blades as per Robs post cost less than £40 all on with bits from a scrap golf 4 and takes less than 30 mins with the right tools. Thoroughly recommended - perfect wipe and huge improvement over standard.
Edited by Girardi
Link to comment
Share on other sites
I reckon you can do a retro fit aero on the rear (try wiperblades.co.uk) to match up with golf arms and blades up front as suggested. I had a retro fit on the rear, was fine, and like Girardi I tried and failed with retro options on the front, rear was ok though.
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
