Help pls - which battery?
Recommended Posts
Dude, then measure the space you have available and use the chart to find a battery to fit, you're not a 'creative' by any chance are you?
ECP has or had 063 batteries on special at £35 which may fit. You don't really need anything bigger since it's only a petrol and a bigger battery will just take slightly longer to go flat when you forget to switch your lights off!
Link to comment
Share on other sites
Make sure you have your radio code if it has one, wipe a little vaseline or lithium grease round the posts on the new battery (don't use copaslip, it's a terrible conductor), then just swap 'em over, you can take the old battery to your local household recycling depot.
Link to comment
Don't bother with the Lion ones from ECP. I fitted one earlier in the year and it's showing signs of weakness already (PAS light coming on at cold start).
I wouldn't bother on a diesel, however on a little petrol car it's fine, I know, I have one and no issues at all.
Link to comment
I believe it's after to seal. It's only to seal , if you put before that will prevent contact...
No, no it won't.
It's not to seal, it's to prevent electrolytic corrosion between the terminal and the post. Look it up if you skipped science at school.
Link to comment
Just a quick message to report back that I completed this job today thanks to the help from this great forum. I upgraded from the original (I believe) 44Ah battery, which to be fair has lasted an incredible 10 years (almost 9 years of which in my ownership), to a 60Ah Bosch S4 027 battery, it's slightly larger than the existing battery, but still fits nicely in the tray.
At first glance it looked like a far more complicated procedure than on other cars, but it was actually a really simple job. I just undid the terminals, unclipped the lugs holding the tray down, pulled off the battery tray leaving the cables connected, undid 1 securing bolt, removed the old battery and installation was the reverse. I applied some vasaline on the terminals before and after.
I gave starting the engine a test and wow what a difference. Near instantanious start, felt like it had been given a new lease of life. Thankfully my radio self installed the code, I reset the clock and it rembered the anti-hi jack auto lock setting, so all is good. Another job ticked off the list, well chuffed, thanks again.
Link to comment
  • 4 weeks later...
More crank amps makes better start. More capacity- no.
Mine original battery (Acuma) lasted 7 years + 7 months...replaced it with Yuasa YBX5063... and got extra free space under fuse's tray, hahaha.
Link to comment
Again, another post where if we knew roughly where the poster lived, one or more could direct him /her/ them to a place locally to get a decent deal ,and disposal. e.g, my locale is given as Nuneaton, where i know from lots of year car ownership that Britannia take a lot of beating for batteries over a vast range of cars. But Britannia also have branches in places like Derby and Bristol, so they might be worth out checking in those places.
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
