Fitted OEM bluetooth module
drw8
Recommended Posts
As the title, fitted the Bluetooth module I picked up off of ebay and its working fine as far as I'm aware. Having a bit of difficulty trying to locate the module either behind the climate controls or the glove box.
Anyway, connected 2 phones (iphone 5 and htc one mini 2) and it imports the phone books and works fine. Is there anything else that it can do? Read a bit about Bluetooth streaming, how does that work?
Thanks, Drew.
Link to comment
Share on other sites
As far as I know it is fully functioning, just hoping someone who has more knowledge on the matter could enlighten me if it wasn't. Basically I don't know what it should do.
Link to comment
Factory fitted it goes under the driver's seat.
Get it coded in with VCDS and clear the fault codes. I doubt you'll get any more functionality than control from the Maxidot though
Link to comment
Factory fitted, it has a metal cradle that is screwed to mounting points in the floor.
I originally had my BT model retrofitted into a foam cradle and the velcro never held very well; so I went to the proper kit.
No way it was going to move then!
Link to comment
In my phonebook, contacts are saved as John Smith, but when going through the phone book via the bolero it is displayed as Smith John. Is this something that can be sorted with a scan/fault clear?
Not had the time to get it checked out with VCDS yet, due to working offshore.
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
