Lane Assist activation via VCDS?
Recommended Posts
Has anyone played with VCDS on their new Superb?
From what I have seen so far, it seems that cars with factory fitted HBA/FLA (High Beam Assistant) has a camera very similar to the camera used for Lane Assist - unlike "older" cars, Octavia III and so on.
So, the big question is, if it might be possible to activate Lane Assist via VCDS coding, if the car comes with HBA camera?
Cant wait to get hold of my own new Superb, but the lead times are SO long. So I think I´ll see summer before a new car arrives.
Link to comment
Share on other sites
Looks promising but I wouldn't advise trying it yet. The comment at the bottom (Gerry W) is someone who tried it and lost their sign-recognition/navigation link.
I've read about others bring to add/change settings and losing other features, so until the VCDS software is brought up-to-date for the current models I will definitely be leaving mine alone.
Link to comment
My car doesn't arrive before next year, so hopefully Ross Tech has sorted it out in the meantime :)
It could be nice if somone with a S3 equipped with HBA/FLA could post a VCDS autoscan to discover which type of camera it is.
Edited by GaSelle
Link to comment
Here you go:
Monday,30,November,2015,11:55:18:22041
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 15.7.1.0
Data version: 20150904
www.Ross-Tech.com
VIN: TMBBJ9NP9G702****   License Plate: **65***
Mileage: 4   Repair Order: Delivery
Chassis Type: NP (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 2B 36 3C 42 44 52 55
          5F 6C 6D A5
VIN: TMBBJ9NP9G7029918
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: Malfunction 0010
14-Susp. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
Address 01: Engine (J623-DFCA)       Labels: 04L-907-309-V1.clb
   Part No SW: 04L 906 026 FN    HW: 04L 907 309 M
   Component: R4 2,0L EDC   H23 1195
   Revision: B4H23---
   Coding: 011D0032036501083000
   Shop #: WSC 33361 790 00063
   ASAM Dataset: EV_ECM20TDI01104L906026FN 002001
   ROD: EV_ECM20TDI01104L906026FN_SK48.rod
   VCID: 7BFE421BF2B379E608-802E
No fault code found.
Readiness: 0 0 0 0 1
Address 02: Auto Trans (J743)       Labels: 0D9-927-770.clb
   Part No SW: 0D9 300 041 B    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H53 4803
   Revision: 06253104    Serial number: TFK01509242689
   Coding: 0014
   ASAM Dataset: EV_TCMDQ250021 001001
   ROD: EV_TCMDQ250021_AU37.rod
   VCID: 17367EABEEDBBD868C-8042
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-IPB-V1.clb
   Part No SW: 3Q0 907 379 AB    HW: 3Q0 907 379 G
   Component: ESC           H42 0723
   Revision: 00000000    Serial number: 62725000002243
   Coding: 1D07929C34220B750780060141CB49B8492CD0E0608292F53861F0F8C2A9
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 034036
   ROD: EV_Brake1UDSContiMK100IPB_SK37.rod
   VCID: 7AF0471FFD8940EE13-802E
Address 05: Acc/Start Auth. (J518)       Labels: 5Q0-959-435.clb
   Part No SW: 3Q0 959 435 C    HW: 3Q0 959 435 C
   Component: VWKESSYMQB    036 0710
   Revision: 00036000    Serial number: 0382855505
   Coding: 030C0C0703
   ASAM Dataset: EV_KessyHellaMQBAB 004032
   ROD: EV_KessyHellaMQBAB_SK48.rod
   VCID: 3A70871FBD0980EE53-806E
   Subsystem 2 - Part No SW: 3AA 962 243 E    HW: 3AA 962 243 E
   Component: GEB.F.Heckoef  H16 0813
   Serial number: 65032489
1 Fault Found:
1077250 - ROD - Unknown Error Code
          - 00 [008]
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 13
                    Reset counter: 40
                    Mileage: 3 km
                    Date: 2011.10.22
                    Time: 12:21:09
Address 08: Auto HVAC (E87)       Labels: None
   Part No SW: 3V0 907 044 AN    HW: 3V0 907 044 AN
   Component: AC Automat    H32 3601
   Revision: 20K04000    Serial number: 00000B00027973
   Coding: 11110104000400011005100100101102
   ASAM Dataset: EV_ACClimaPrehVW37X 002009
   ROD: EV_ACClimaPrehVW37X_SK48.rod
   VCID: 000435F79B551A3E5D-8054
   Slave 1:
1 Fault Found:
0515 - Transport Mode Active
          U1105 00 [008] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 17
                    Reset counter: 40
                    Mileage: 3 km
                    Date: 2011.10.22
                    Time: 12:21:09
Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-HV1.clb
   Part No SW: 5Q0 937 084 AS    HW: 5Q0 937 084 AN
   Component: BCM MQBAB H   H24 0175
   Serial number: 01061528007986
   Coding: 0F019E66C2C72AFB17844086B118172C0800000000000000000000000000
   ASAM Dataset: EV_BCMMQB 015001
   ROD: EV_BCMBOSCH_SK48.rod
   VCID: 091228D3A86F5B760A-805C
   Slave 1:
   Subsystem 1 - Part No SW: 3V2 955 119     HW: 3V1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: 48x RL 150225  032 0121
   Serial number: 00000001502210602013
   Coding: 165DDD
   Slave 2:
   Subsystem 2 - Part No SW: 5Q0 955 547 A    HW: 5Q0 955 547 A  Labels: 5Q0-955-547.CLB
   Component: RLHS  037 0059
   Serial number: S4Y15M10D19H01M57S19
   Coding: 0088DF
   Subsystem 3 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Component: Sensor, DWA  005 0316
   Serial number: 000000000ZY1523614FM
   Subsystem 4 - Part No SW: 5Q0 951 605     HW: 5Q0 951 605
   Component: Sirene, DWA  004 0311
   Serial number: 00000000000033597986
   Subsystem 5 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Component: SysNameFanLin  014 0101
   Serial number: ESE0048458
   Subsystem 6 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE0105694
   Subsystem 7 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE0102725
   Subsystem 8 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE0105695
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-298.clb
   Part No SW: 5QA 919 298     HW: 5Q0 919 298 C
   Component: PLA 3.0 12KH08 0161
   Serial number: 000305183615269
   Coding: 0371167851
   ASAM Dataset: EV_EPHVA2CAU3700000 009017
   ROD: EV_EPHVA2CAU3700000_SK48.rod
   VCID: 0D1A1CC3DC07475626-8058
Address 13: Auto Dist. Reg (J428)       Labels: None
   Part No SW: 3Q0 907 572 B    HW: 3Q0 907 572 B
   Component: ACC BOSCH MQB H04 0192
   Coding: 320067C355FFC428949C804D
   ASAM Dataset: EV_ACCBOSCHVW48X 001008
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 346CA9279F6D769E89-8060
1 Fault Found:
0110 - Transport Mode Active
          U1105 00 [008] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 3 km
                    Date: 2011.10.22
                    Time: 12:21:09
Address 14: Susp. Elect. (J250)       Labels: 5Q0-907-376.clb
   Part No SW: 5Q0 907 376 A    HW: 5Q0 907 376 A
   Component: DAEMPFUNGS-SG H17 0120
   Serial number: 16101541350715
   ASAM Dataset: EV_DRCONTITEMIC 001019
   ROD: EV_DRCONTITEMIC.rod
   VCID: 37769E2B8E1B9D86AC-8062
Address 15: Airbags (J234)       Labels: 5Q0-959-655.clb
   Part No SW: 5Q0 959 655 AE    HW: 5Q0 959 655 AE
   Component: AirbagVW21    005 0130
   Serial number: 003NSR15TKCJ
   Coding: 98FCC0C0000000005C5400CF00C800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002146
   ROD: EV_AirbaVW20SMEVW37X_SK48.rod
   VCID: 030E3AFB8A43012640-8056
   Seat belt tensioner; left:
   Subsystem 1 - Part No SW: 4M0 980 945 A    HW: 4M0 980 945 A
   Component: BeltPretRevFL  106 1032
   Serial number: 3V0857701C0285P00576
   Coding: 80000D
   Seat belt tensioner; right:
   Subsystem 2 - Part No SW: 4M0 980 946 A    HW: 4M0 980 946 A
   Component: BeltPretRevFR  106 1032
   Serial number: 3V0857702C0283P01085
   Coding: 80000D
   Crash sensor for side airbag; driver side:
   Subsystem 3 - Part No SW: -----------    HW: 480 000 110 15
   Component: SideSensor_Df  001 0887
   Serial number: 35700000000309FCB61T
   Coding: 2D2D2D
   Crash sensor for side airbag; front passenger side:
   Subsystem 4 - Part No SW: -----------    HW: 480 000 110 15
   Component: SideSensor_Pf  001 0887
   Serial number: 35800000000026290710
   Coding: 2D2D2D
   Crash sensor for side airbag; rear; driver side:
   Subsystem 5 - Part No SW: -----------    HW: 480 400 510 15
   Component: SideSensor_Dr  001 6149
   Serial number: 3510002A11CF2D70D289
   Coding: 2D2D2D
   Crash sensor for side airbag; rear; passenger side:
   Subsystem 6 - Part No SW: -----------    HW: 480 400 510 15
   Component: SideSensor_Pr  001 6149
   Serial number: 3520002B91CF2DA3335D
   Coding: 2D2D2D
   Crash sensor for front airbag; driver side:
   Subsystem 7 - Part No SW: -----------    HW: 480 403 009 15
   Component: FrontSensor_D  001 6149
   Serial number: 3550002C91CF2D75534H
   Coding: 2D2D2D
Address 16: Steering wheel (J524)       Labels: 5Q0-953-549.clb
   Part No SW: 3Q0 953 521 BA    HW: 5Q0 953 569 A
   Component: Lenks.Modul   075 0195
   Revision: FF033033    Serial number: 20151007400651
   Coding: 6010
   ASAM Dataset: EV_SMLSVALEOMQB 001015
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 70E46537ABF50ABEAD-8024
Address 17: Instruments (J285)       Labels: None
   Part No SW: 3V0 920 911     HW: 3V0 920 911
   Component: KOMBI         305 6422
   Coding: 27A5011A7F80A600018B6A0B5001000000000000
   Shop #: WSC 73430 031 00063
   ASAM Dataset: EV_DashBoardVDDMQBAB 009046
   ROD: EV_DashBoardVDDMQBAB_SK25.rod
   VCID: 6FE6664BB6CB1546B4-803A
Address 19: CAN Gateway (J533)       Labels: 5Q0-907-530-V1.clb
   Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2227
   Revision: --------    Serial number: 13101510802143
   Coding: 030100044F087300EB00025E9C0F00010001070000000000000000000000
   Shop #: WSC 73430 790 00063
   ASAM Dataset: EV_GatewConti 013020
   ROD: EV_GatewConti.rod
   VCID: 75EA5423D4972F967E-8020
   Alternator:
   Multifunction unit control module:
   Subsystem 2 - Part No SW: 3V0 919 719 B    HW: 3V0 919 719 B
   Component: E221__MFL-PR6  H02 0150
   Serial number: 000000000A2937081015
   Battery Monitoring Control Module:
   Subsystem 3 - Part No SW: 5Q0 915 181 G    HW: 5Q0 915 181 G
   Component: J367-BDMHella  H04 8050
   Serial number: 0876128103
Address 2B: Steer. Col. Lock (J764)       Labels: 5Q0-905-861.clb
   Part No SW: 3Q0 905 861     HW: 3Q0 905 861
   Component: ELV-MQBB      H05 0031
   Serial number: 15000073687004
   Coding: 0800000000000000
   ASAM Dataset: EV_ELVMarquMQBB 001007
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71E26033A0FF03B6A2-8024
Address 36: Seat Mem. Drvr (J810)       Labels: None
   Part No SW: 5Q0 959 760 A    HW: 5Q0 959 760 A
   Component: Sitzmemory    H06 0009
   Serial number: Y0006OIG13839
   Coding: 001400000000010001A080808080000000008181000000D4
   ASAM Dataset: EV_SeatMemorDriveSide 001015
   ROD: EV_SeatMemorDriveSide_SK37.rod
   VCID: 3B7E821BB233B9E648-806E
Address 3C: Lane Change (J1086)       Labels: None
   Part No SW: 5Q0 907 686 B    HW: 5Q0 907 686 B
   Component: HRE_Master    H11 0071
   Serial number: 0381848004
   Coding: 02011203
   ASAM Dataset: EV_HREntryHella 001028
   ROD: EV_HREntryHella_SK37.rod
   VCID: 3C7C8107B73DBEDE41-8068
   Lane Change Assistant 2:
Address 42: Door Elect, Driver (J386)       Labels: 5QX-959-X93-42.clb
   Part No SW: 5Q0 959 593 E    HW: 5Q0 959 593 B
   Component: TSG FS        020 0041
   Serial number: 150915BIF02812
   Coding: 001D0820DE01048000001100
   ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
   ROD: EV_DCUDriveSideEWMAXCONT_SK37.rod
   VCID: 438EFAFBCAC3C12600-8016
Address 44: Steering Assist (J500)       Labels: 5Q0-909-144.clb
   Part No SW: 5Q0 909 144 S    HW: 5Q0 909 144 R
   Component: EPS_MQB_ZFLS  125 1063
   Coding: 9303
   ASAM Dataset: EV_SteerAssisMQB 012140
   ROD: EV_SteerAssisMQB.rod
   VCID: 448CF9E7CFCDC61E39-8010
Address 52: Door Elect, Pass. (J387)       Labels: 5QX-959-X92-52.clb
   Part No SW: 5Q0 959 592 E    HW: 5Q0 959 592 B
   Component: TSG BFS       020 0041
   Serial number: 250915BIO15667
   Coding: 001D0220DE01048000001100
   ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
   ROD: EV_DCUPasseSideEWMAXCONT_SK37.rod
   VCID: 4280FFFFD5D9C82E0B-8016
Address 55: Headlight Range (J745)       Labels: 7P6-907-357.clb
   Part No SW: 7P6 907 357 D    HW: 7P6 907 357 A
   Component: AFS-ECU       H07 0090
   Revision: --------    Serial number: --------------
   Coding: 06D602007F010000
   ASAM Dataset: EV_HeadlRegulVWAFSMQB 001120
   ROD: EV_HeadlRegulVWAFS_SE26.rod
   VCID: 4084F5F7DBD5DA3E1D-8014
   Subsystem 1 - Part No SW: 4H0 941 329     HW: 4H0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H02 0013
   Coding: B30000
   Subsystem 2 - Part No SW: 4H0 941 329     HW: 4H0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H02 0013
   Coding: B30000
Address 5F: Information Electr. (J794)       Labels: None
   Part No SW: 3V0 035 020 A    HW: 3V0 035 020
   Component: MU-H-ND-EU    H42 0318
   Serial number: A435J0F7522308
   Coding: 038401010000000011111202008808002F0003E601200100DE
   ASAM Dataset: EV_MUHig4CGen2HBAS 001001
   ROD: EV_MUHig4CGen2HBAS_SK37.rod
   VCID: 244C59672F8DE61E19-8070
   Media Player Position 1:
   Radio Tuner - Digital:
   Subsystem 2 - Part No SW: 3V0 919 606     HW: 3V0 919 606
   Component: ABT_High-2  H44 1028
   Serial number: SKZ8Z9RAM00BJX
   Engine Control Module 2:
   Subsystem 3 - Part No SW: -----------    HW: -----------
   Component: -------------  --- ----
   Serial number: --------------------
   Seat Adjustment Driver Side:
   Subsystem 4 - Part No SW: V03 959 801 JJ    HW: -----------
   Component: ECE 2015/2016  --- 0122
   Air Conditioning Compressor:
   Diesel Pump Control Unit:
   Door Electronics Driver Side:
   Subsystem 7 - Part No SW: -----------    HW: -----------
   Brake Assistance:
   Subsystem 8 - Part No SW: -----------    HW: -----------
   Interior Monitoring:
   Subsystem 9 - Part No SW: -----------    HW: -----------
   Sound System:
   Door Electronics Rear Left:
   Subsystem 12 - Part No SW: -----------    HW: -----------
   Subsystem 13 - Part No SW: -----------    HW: -----------
   Subsystem 14 - Part No SW: V03 959 800 EG    HW: -----------
   Component: Gracenote2  --- 1011
Address 6C: Back-up Cam. (J772)       Labels: None
   Part No SW: 5Q0 980 556     HW: 5Q0 980 556
   Component: RVC Compact   H07 0100
   Coding: 04840101A600201F000040
   ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 005007
   ROD: EV_CamSysRVRVCPANAMQBAB.rod
   VCID: 77F65E2BCE9B5D866C-8022
Address 6D: Trunk Elect. (J605)       Labels: None
   Part No SW: 5Q0 959 107 G    HW: 5Q0 959 107 G
   Component: HDSG-Modul    H12 0250
   Revision: --------    Serial number: 30282636500000
   Coding: 1008
   ASAM Dataset: EV_DeckLidCONTIAU736 001011
   ROD: EV_DeckLidCONTIAU736_SK48.rod
Address A5: Frt Sens. Drv. Assist (R242)       Labels: None
   Part No SW: 3Q0 980 654 D    HW: 3Q0 980 654
   Component: MQB_B_MFK     H04 0024
   Serial number: 05101511K11646
   Coding: 020408010000040100062346C040A00088000E100040
   ASAM Dataset: EV_MFKBoschMQBB 001001
   ROD: EV_MFKBoschMQBB_SK48.rod
   VCID: 38749D17830592FEA5-806C
End-------------------------(Elapsed Time: 07:22)--------------------------
Link to comment
Thank you so much! This car has Lane Assist, right? Could be interesting to see a scan from a car with FLA/HBA only. It seems like it's the camera A5 that is needed for Lane Assist.
Link to comment
Yes it has lane assist, (part of the Smart Light Assist package)
I imagine there will be hardware that needs to be added, my car was not ordered with “Travel assist with Traffic sign recognition and display as I have coded Octavias and no additional hardware was needed, this I am hoping to do to mine when Ross-Tech sort out 5F
Link to comment
New version 15.7.2 has been released
Link to comment
So do I need to spec traffic sign assist to get the better camera hardware so I can activate lane assist later via VCDS?
It's not on my order now but will be if you pros think it wise to so. Any advice would be welcome.
Edited by blahde2
Link to comment
I have spoken with an owner of Superb 3 with only Light Assist and he told me, that he has a camera on windscreen, so should be A5 and not under the rearview mirror, which is 20. I am waiting for a picture of the camera. But according to information that I have until now, it looks like that Superb has A5 also with Light Assist. So Light Assist should be enough. Though, you take your chances on your own risk, since this is not yet 100% confirmed.
If TSA is ordered it should be enough also for Lane Assist.
  • Like 1
Link to comment
That was what I found out as well so far. Will be exciting, when VCDS gets updated and someone gives it a shot. Unfortunately my car does not arrive before the new year.
  • Like 1
Link to comment
I haven't gambled, I specced TSA at £85 as it's not possible to upgrade once built. If it can read a road sign then the resolution must be high enough to read the road lines. Lets hope it is.
Taa for the response none the less.
Link to comment
Think the camera is the same. Over here TSA is part of a pack costing £1000, and requires you order nav as well. So won't be ticking that box!
Link to comment
  • 2 months later...
Hi all,
My car originally came without smart light assistant+lane assistant+blind spot. But I had packet style plus with ACC and traffic sign recognition and separately blind spot detection.
I successfully coded lane assistant. This log (http://www.briskoda.net/forums/topic/380299-lane-assist-activation-via-vcds/#entry4456595) was for me very useful.  J
Lane assistant works fine.
Emergency assistant is activating too in case when I am not holding steering wheel. Car is slowly stopped but WARNING LIGHTS a not flashing.
Has anybody idea how to fix it? I can’t find this option in VCDS adaptations L
my orig coding:
Friday,22,January,2016,16:56:58:46612
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
VCDS Version: 15.7.3.0 (x64)
Data version: 20151216
www.Ross-Tech.com
Mileage: 1181km-733mi   Repair Order:
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 18 19 2B 36 3C 42 44 52
          55 5F 69 6C 6D A5
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
18-Aux. Heat -- Status: OK 0000
69-Trailer -- Status: OK 0000
Address 01: Engine (J623-CRLB)       Labels: 04L-907-309-V1.clb
   Part No SW: 04L 906 026 ET    HW: 04L 907 309 R
   Component: R4 2,0L EDC   H22 1343
   Revision: B5H22---
   Coding: 011D003A047401083000
   Part No SW: 0D9 300 041 H    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H53 4905
   Coding: 0014
   Coding: 1D076A9C34240B700780060741C649B8562CD0E0608292F53861F0F8C282
   Coding: 030C0C0703
   Part No SW: 3V0 907 044 AK    HW: 3V0 907 044 AK
   Component: AC Automat    H32 3701
   Coding: 11010104004401011005100100101102
   ASAM Dataset: EV_ACClimaPrehVW37X 002012
   Slave 1:
   Coding: 0C031B66C2C722FB17A44086B118172C0C00000000000000000000000000
   Slave 1:
   Subsystem 1 - Part No SW: 3V1 955 119     HW: 3V1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: 48x LL 151111  032 0121
   Coding: 165DDD
   Slave 2:
   Coding: 0088DF
   Subsystem 4 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Component: Sirene, DWA  005 0312
   Coding: 0271165951
Address 13: Auto Dist. Reg (J428)       Labels: 3Q0-907-572.clb
   Coding: 320067CB51FFC428949C804D
   Coding: 98FCC0C0000000005C5400CF004800000065
   Coding: 80000D
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 480 000 411 15
   Coding: 2D2D2D
   Subsystem 4 - Part No SW: -----------    HW: 480 000 411 15
   Coding: 2D2D2D
   Subsystem 5 - Part No SW: -----------    HW: 480 402 411 15
   Coding: 2D2D2D
   Subsystem 6 - Part No SW: -----------    HW: 480 402 411 15
   Coding: 2D2D2D
   Subsystem 7 - Part No SW: -----------    HW: 480 402 411 15
   Coding: 2D2D2D
   Coding: 6010
Address 17: Instruments (J285)       Labels: 5G0-920-XXX-17.clb
   Part No SW: 3V0 920 751     HW: 3V0 920 751
   Component: KOMBI         313 6422
   Coding: 07A5011A3F84000801886A095001000000000000
Address 18: Aux. Heat (J364)       Labels: 5Q0-963-272.clb
   Part No SW: 5Q0 963 272 E    HW: 5Q0 963 272 E
   Component: STH-MQB       007 0072
   Coding: 9309
   ASAM Dataset: EV_AuxilParkiHeateWOS 002018
   ROD: EV_AuxilParkiHeateWOS_AU37.rod
   Subsystem 1 - Part No SW: 5Q0 963 513 A    HW: 5Q0 963 513 A
   Component: R149 T91-LIN  003 0301
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2246
   Coding: 0B0100345F087300EB00025E9C0F00010001070000000000000000000000
   Alternator:
   Inverter power receptacle:
   Subsystem 4 - Part No SW: 5Q0 907 155 B    HW: 5Q0 907 155 B
   Component: WECHSELRICHTE  H53 0033
   Component: ELV-MQBB      H05 0032
   Coding: 001000000000010001A080808080000000008181000000D4
   Coding: 02012103
   Coding: 001D0820DE00048000001100
   Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A
   Component: FOND_FHSG_DRV  005 0005
   Coding: 110200
Address 44: Steering Assist (J500)       Labels: 5Q0-909-143.clb
   Part No SW: 5Q0 909 143 M    HW: 5Q0 909 143 E
   Component: MQB_PP_APA    204 2041
   Coding: 01010010005001
   ASAM Dataset: EV_SteerAssisVWBSMQBA 008028
   ROD: EV_SteerAssisVWBSMQBA_SK48.rod
   Coding: 001D0220DE00048000001100
   Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A
   Component: FOND_FHSG_PSG  005 0005
   Coding: 090200
   Coding: 06D202003F010000
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0006
   Coding: B20000
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0006
   Coding: B20000
   Part No SW: 3V0 035 020 B    HW: 3V0 035 020
   Component: MU-H-ND-EU    H50 0318
   Coding: 03840101000000001111120200800A002F0000E4012001009E
   Component: ABT_High-2  H46 1031
   Subsystem 4 - Part No SW: V03 959 801 JK    HW: -----------
   Component: ECE 2016  --- 0134
   Brake Assistance:
   Sound System:
   Component: Gracenote2  --- 1012
Address 69: Trailer (J345)       Labels: 5Q0-907-383.clb
   Part No SW: 5Q0 907 383 H    HW: 5Q0 907 383 C
   Component: Anhaenger     H21 0203
   Coding: 0100000202000000
   ASAM Dataset: EV_TrailFunctGener2Hella 001008
   ROD: EV_TrailFunctGener2Hella_AU37.rod
   Component: RVC Compact   H09 0170
   Coding: 04840101A700201F000040
   Part No SW: 5Q0 959 107 J    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0253
   Coding: 1088
   ASAM Dataset: EV_DeckLidCONTIAU736 001012
   Coding: 020408010000040100262347C040A00010000E100020
End-------------------------(Elapsed Time: 06:12)--------------------------
my new coding with lane assistant:
Wednesday,03,February,2016,00:59:51:08875
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
www.Ross-Tech.com
Mileage: 2019km-1254mi   Repair Order:
          55 5F 69 6C 6D A5
   Revision: B5H22---
   Coding: 0014
   Coding: 030C0C0703
   Coding: 11010104004401011005104100101102
   Slave 1:
   Slave 1:
   Coding: 165DDD
   Slave 2:
   Coding: 0088DF
   Coding: 0271165951
   Coding: 320067CB55FFC428949C804D
   Coding: 80000D
   Coding: 80000D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 6010
   Coding: 07A5011A7F84000801886A0B5001000000000000
   Coding: 9309
   Alternator:
   Coding: 02012103
   Coding: 110200
   Coding: 01010011005001
   Coding: 090200
   Coding: B20000
   Coding: B20000
   Brake Assistance:
   Sound System:
   Coding: 1088
   Coding: 020408010000040100262347C040A00098000E100020
End-------------------------(Elapsed Time: 06:06)--------------------------
Edited by CVK@Baca
Link to comment
Could you maybe post a direct guide on how to code? Thanks :)
I used long coding:
my orig coding     Coding: 320067CB51FFC428949C804D
my new coding     Coding: 320067CB55FFC428949C804D
my orig coding    Coding: 07A5011A3F84000801886A095001000000000000
my new coding     Coding: 07A5011A7F84000801886A0B5001000000000000
my orig coding    Coding: 01010010005001
my new coding     Coding: 01010011005001
my orig coding    Coding: 03840101000000001111120200800A002F0000E4012001009E
my new coding     Coding: 038401010000000011111202008808002F0003E601200100DE
my orig coding    Coding: 020408010000040100262347C040A00010000E100020
my new coding     Coding: 020408010000040100262347C040A00098000E100020
Edited by CVK@Baca
  • Like 1
Link to comment
Any hints how to activate warning lights when emergency assistant starts braking process?
Problem solved :)
to activate turn lights warnirnig, change bit 7 in central electronic (09) to 2A
Coding: 0C031B66C2C72AFB17A44086B118172C0C00000000000000000000000000
Edited by CVK@Baca
Link to comment
  • 5 months later...
Not sure if its ok to resurrect old threads here :) But I am ordering my superb soon, and this is one of the most useful info I found about this car
So I just wanted to double check - does this still work on new cars? what do I need to order to activate the lane assist, is it the TSR (which need navi, so maybe 500eur), or is "Intelligent light assistant - auto-switch headlights on/off" enough? (costs only 200e) I dont care about the navi or TSR so could as well save 300e and order something else
Anything else needed for lane assist?
Edited by pichalsi
Link to comment
  • 1 year later...
I have not been able to make Lane Assist work. If it appears in the maxidot but when I choose the option of Lane Assist tells me that it is not available. The car has the big camera and high beam light assist but I can not activate it and in the browser, in the section of driving assistants does not appear either.
Link to comment
  • 4 months later...
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
