Goodyear Efficientgrip Performance tyres
kentphil1
Recommended Posts
Hi all,
There seems to be a regular question on here every now and then as to what tyre to fit on a mk1 Octavia Vrs.
I have over the last 4 years had Continental Sport Contact 3's and sport contact 5's, each time on all 4 tyres so no mixing and matching, so I can give a genuine opinion based on their performance at all corners of the car. Both the Continentals 3 and 5 offer good dry grip, and good wet weather grip, with a fairly good amount of grip in temps down to about 0 degrees. Whilst they offer grip at that temperature, they are no winter tyre, just fairly good as normal tyres go.
The Contact 5's seem to lose their "edge" once the tread depth drops under 3.5 mm, which considering they only come with about 6mm when new means you don't get full performance from the wear of the tyre, they also emit a lot more road noise once wear passes 3.5mm.
I have now gone for Goodyear efficientgrip performance tyres in the standard 205/50/17 size, and whilst I have only put about 300 miles on the tyres so far, my initial impressions are very favourable. Wet weather grip seems to feel more sure footed, mainly because the Goodyear's seem to feed back more feel as to what is going on at the wheels allowing you to control the car much more positively. Braking is hard to judge yet as the tyres are new and not fully bedded in yet, but it appears to be at least as good as the Conti's, and I think it will probably get better.
The one thing that is so obvious even though the tyres are not fully bedded yet is how much less roadnoise is in the car. I would say it is about 10% less than the Conti's when new, and is really noticeable over regular roads that I drive on compared to the Conti's.
Once the tyres are bedded down, I will try to give more info on dry and wet braking to make it a fairer comparison, but my initial impression is that I did not waste my money here and that there is the start of a big smile on my face. One last thing, to keep the opinion fair, tha car always has a 4 wheel alignment at the same time as the new tyres are fitted, so any misalignment is ruled out to cause any skewing of the opinion.
I hope this of some interest to some of you, and I will update in about 4 weeks to complete the comparison.
Have a good Christmas,
Phil.
Edited by kentphil1
  • Like 1
Link to comment
Share on other sites
I've had Continental's on my car since having them on a new car in 2000. I even changed to them when I got the Roomster. I never thought i'd use anything else, UNTILL, August of last year when, after reading up about the Goodyears above, decided to change, have to agree with all that kentphil1 said.   :clap:
  • Like 2
Link to comment
I did a fair bit of reading before I plumped for the Goodyears, the noise reduction was really surprising. I still have a few gremlins to work out with regards mpg etc but so far they are cracking.
Link to comment
I have these on my Yeti and had them on my Octavia before that. I like them - last longer than Continetal tyres, quieter than most, fuel economy is up by 3-5 mpg on both cars, driving response seems no different. And they are one of the cheapest 'premium' brands in my tyre size.
What's not to like?
Link to comment
Yeah the price of them is really good for a premium tyre. £57 a corner fitted for my car.
Will definitely be getting some once I've had the alloys refurbished for summer.
Link to comment
Isn't the Yeti 225/50/17? If so then this is a bit more of an unusual size. If they'd been 225/45/17 then that'll be common and cheaper!
Very impressed when ran on our previous C'eed. Can't get them in 205/45/16 sized but can in 195/55/15.... Do I sense a wheel change for the Fabia coming up?
Link to comment
  • 2 months later...
Hi
I too moved from Continentals to Goodyears this year, mine are 18" and of all the places I found Kwik fit online the best price at the time(End of Jan) at £80.99 which is not too bad. I am very pleased with the level of grip and the noticeable difference in noise. time will tell what they are like for wear but all looks well so far.
Another very happy customer here.
  • Like 1
Link to comment
So had some if these fitted on Tuesday. Very pleased with them.
They are nice and quiet, seem to be helping with the MPG and when I did a spot of "spirited" driving earlier my face was nearly ripped off from the g force... brilliant grip!
Link to comment
Thought I'd add an update to mine. They have been fitted for just over 20,000 miles (about 15% motorway) and I'm just thinking about changing them on my Yeti (2 litre Tdi 170) as there is just over 2mm of tread left on all tyres (I had front and rears swapped a few thousand miles back).
Edited by KBPhoto
Link to comment
As above the fronts on mine have done about 19k (12 months old) and they are now almost due for renewal.
Probably due in the next week or so.
Not sure what I'm going for next though.
Link to comment
If you've been happy with them why not the same? Or perhaps the F1A3 instead?
Link to comment
Due to the millage I'm doing of circa 20k per year I'm leaning towards a tire that offers more in the winter.
The efficient grip is great in the wet and summer, but when the temperature drops or there's snow about then it's not very good.
Looking at all options at the moment, probably not an all season tire but one that's got a lower wet weather rating but with a more blocky type tread.
Link to comment
  • 3 months later...
are the goodyear efficentgrip performance tyres run flats as been on blackcircles and foun them for 225/40/18 for 80 pound each fitted but says re enforced walls dose that mean run flats?
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
