136 Rapid 1.3 spark plugs
Recommended Posts
Hi. I recently became owner of a 136 Rapid, 1.3, manufactured in 1989. According to a couple of car spares websites, my car should be fitted with NGK BP6HS spark plugs. But when I tried to fit these, the nut is too big & I can't get the plug spanner to fit . The car came with NGK BP7EFS plugs fitted.... are these the right ones to use ? I do have some running issues with the car at the moment & am trying to eliminate various things. It would help a lot knowing which plugs should be fitted. many thanks for any help...
Link to comment
Share on other sites
If your car is fitted with the longer plugs the electrodes will be touching the pistons at high revs because they will protrude too far.....that would cause issues! I did this once and the engine did run but closed the electrodes up and ran like a dog! Worth swapping for the correct ones......doesn't matter much if you use 6 or 7 on the heat rating.
Link to comment
Those are both 14mm (BP) but different heat grade (6 is hotter than 7) and thread length.
 https://www.ngk.de/fileadmin/Dokumente/EN/downloads_not_used_in_download_area/ngk_zuendkerzen_code_en.pdf
In fact, the one plug probably won't fit (correctly) in a mount machined for the other.
Thanks Ken.
Link to comment
Thanks. The 7's are longer, but on the 6's, the hexagonal nut is bigger, & fits so close to the cylinder head, that I can't get the plug spanner around to tighten them. I guess I'll keep on using the 7's, unless something nasty happens. Just wondered what other people use....Cheers.
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
