Comfort control module or Convenience control module.
Elgey1
Recommended Posts
Can anybody tell me if Comfort control is different to the Convenience control module? and if they are where do I find the Convenience control module.  I am in the process of trying to sort the dreaded ingress problem and found the Comfort control but before I put it into the auto electrician I want to sort as many of the problems as I can.
I have lost internal light, locking the car from the fob, windows, sunroof and mirrors.
Any help is much appreciated and thank you in advance lads.
Mark
Link to comment
Share on other sites
They are one and the same, to my knowledge at least.
By the sound of your issues, the CCM or the wiring loom or both are the issue...
Replacing the CCM is expensive, so make sure you know which is the culprit, I would start first looking for corroded wires/nodes and afterwards looking into the CCM.
If you have a good electrician, he will check first if the CCM is salvageable, by opening it (corroded transistors/diodes may be replaced by a skilled hand).
Good luck.
Trimis de pe al meu D5803 folosind Tapatalk
  • Like 1
Link to comment
Thank you very much bud at least I am not chasing something that isn't there now. Hopefully get to the bottom of it all this weekend. Thanks again mate very much appreciated.
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
