Pad of center armrest und rear wiper change
Recommended Posts
Hello community,
I need some advice how I can solve the sliding pad on my center armrest. It needs new foam and maybe new leather.
Clicking out the bottom plastic cover ?
and second:
How to change the rear wiper ?
Thanks in advance
Ulrich
Edited by 0ctavist
Link to comment
Share on other sites
  • 3 months later...
Okay, wiper changed - THANKS for that
Any idea for opening the armrest pad ?
Hi, Did you find a solution? I have the same problem, no clue how to remove /open te armrest pad. And of course the seller doesn't respond........claiming on his site it's an easy install :envy:
Link to comment
New arm rest cover from super Skoda? Just slides on over the existing one
This is a semi- complete armrest. Not just a cover.
@octavist: where did you order? I ordered at cars-equipment.com but they won't answer my Q. I think they sell something without knowing what they sell.
Link to comment
  • 2 months later...
Sorry, until now, no time for the arm rest. But as in 2nd pic above, is only possible with clicking away this plastic cover ......Bedankt en tot ziens
So at the end you have manage to remove sliding pad of armrest?
Link to comment
A few months back someone here (from Norway IIRC) posted some instructions on replacement of the armrest. I'm afraid I can't remember the details but it may be possible to locate the thread with some searching. I did make a note of the process so I'll see if I can find that info.
  • Like 1
Link to comment
I have found it :)
1. Dont need to remove anything else, you see under the lid, theres is a plastic cover.
2. Then you take a flat screwdriver in each corner, and separate the plastic cover from the actual lid. Theres is 4 clips in total.
3. When this is done you push the lid towards the gear knob, and you see that the lid stops against 2 bent metal clips ( i dont know the word, im from norway :p )
4. Just bend the 2 metal clips, then you slide the lid of the box, then you push the 2 metal clips back in place for when you are going to assemble it :)
5. Then you put you new leather over the old one, pop back the plastic cover before you slide it back in place :)
1. Plastic cover of sliding part of the lid?
  or plastic cover of the lid? :)
2. Each corner? but front part of sliding lid has no avaialble corners, in meaning that it is finished with leather.
Some picture, please?
3, 4. ...  I shall see when come to that point :)
Edited by ppejic
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
