Struggle Selecting 1st Gear and Sometimes Gets Stuck?
Recommended Posts
I went to Darkside a few months back and had the Sachs SRE clutch and their own billet SMF fitted - a month or so after It had bedded in I gave it a bit of stick to see how it would cope (nothing too rigorous as I mainly do motorway driving), since then and particularly now, I find selecting first sometimes a struggle and sometimes it can get stuck in first and the car will creep forward with the clutch pressed down; a few dumps of the clutch and I can release first gear and try again which normally works with a bit of a wiggle.
Now, both Darkside and some research from myself came to the VW Vortex thread with a video of a man inserting a shim to stop the selector shaft play. This morning I popped the cover off the side of the gearbox to find no play at all! So, i'm stumped !
Any help appreciated! Thanks.
Link to comment
Share on other sites
It sounds like clutch drag which can either be due to the hyraulics not fully releasing or can be due to warping of the flywheel. Having once changed a clutch only to find the dragging symptom not going away because I hadn't checked and fixed the flywheel with a skim, I sympathise.
Link to comment
Next time it feels hard to push into first pump the clutch pedal up and down fast a few times then see if it drops in better,if it does as above it needs bleeding.
Link to comment
OK will check this tomorrow then bleed on Monday - thanks for the advice :)
  • Like 1
Link to comment
So, I bled the clutch yesterday - the old fluid was a bit poo coloured so glad I did this. So, it has made the gear selection better, but still having an issue this morning selecting reverse. Reset gear linkages next?
  • Like 1
Link to comment
That's prob easiest.
Have you changed gearbox oil?
As it's common with these boxes if the wrong grade oil is used they are notchy to select gears when cold.
Did you try pumping the pedal this morn when it would not select reverse?
Not doubting your ability to bleed the system but they can be awkward to get all the air out :)
Link to comment
Have not changed the gb oil no - I did pump the pedal and it did not seem to make any difference? 1st now seems to be much better (not 100% still), but reverse was a pig this morning. Pretty certain no air in system now, we used EZ bleed kit and did it twice to be sure. I will reset the linkages later, and suppose it is worth changing the gb oil.
Edited by Stuart27183
Link to comment
Don't go to dealers for oil,just get yourself some 75W80 fully synthetic,not 75W90 ;)
If the gear change reset or oil don't sort it I would be worried the Darkside flywheel is not quite right for the Sachs clutch.
I had the Sachs SRE but with the Sachs SMF and gear selection and changes were spot on.
Link to comment
I've ordered some Fuchs 75W80 and the silly tool needed for the drain plug. Will update once done. Thanks for the advice.
  • Like 1
Link to comment
Any further recommendations for the gearbox oil?
Mines tight first thing in the morning as well.
Just gone over 100,000 so going to change my oil as well.
As above,Fuchs is a good brand.
Go on Opie Oils and type in 75W80 gearbox oil then take your pic :)
Link to comment
Link to comment
I had problems with the reverse and 1st being really really notchy like this, gearbox oil change and the reset mechanism to the shift linkeages seem to have sorted it more or less for me.
Could be a bit of issue with wear and tear on the selector on the clutch also apparently I was told with high mileage cars like mine, may benefit from clutch change eventually.
(you have done the obvious thing of the reset of gear linkeages I hope). There should be a video on the forum on this, I've actually got a local copy of it actually.
( Jim Royston from DieselGeek.com shift linkeage adjustment for 2000 and newer Golf Jetta Beetle video )
Link to comment
Thanks, I'll stick the oil on my shopping list.
Will change the gearbox oil and reset the linkage at the same time and see how it goes.
Mines very very minimal really, don't notice it apart from pulling off the drive from first to second.
Link to comment
Just reset the linkages- big improvement but not 100% yet. Selecting 5th and 6th is firmer now and wobbling neutral over to the right is quite firm compared to going left? So much better but not quite there yet as did get slightly stuck in first but wasnt too hard to get it out like it was yesterday. Selecting reverse seems fine now.
  • Like 1
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
