Recommended Posts
Hi All,
Currently on my second Octavia which is generally ace but has suddenly developed a number of electrical issues all together which I suspect is something simple.... I generally have a go at most things but not sure where to start on this one...
Symptoms are
Dashboard
Warning lights on dash come on when indicating
when indicating left the engine management light flashes in time.
When indicating right the engine management light and the foot on brake light flash in time but faintly.
Bonnet open light glows faintly.
Electric Windows
from the drivers door panel:
1 drivers window goes down but not up
Passenger window goes up but not down.
Windows can be shut by holding lock on remote
Rear Window wiper
Stuck in up position sometimes moves when restarting car
Everything else seems to work fine....
Any diagnostic ideas or points to check would be appreciated
J
Link to comment
Share on other sites
Rear wiper motor is probably in need of replacement. It's a common fault and plenty of us have had them fail.
Clocks, could be something to do with the processor In the clocks.
I've had some clock issues myself recently and they are now off for repair.
Windows, I'd be checking that the switches are working.
If they work off the remote, then it's probably something switch related.
Link to comment
Thanks for the reply
It's just a bit strange that all of these things happened at the same time.......and following some really wet weather ,, Also car is usually parked facing uphill and the old MK1 i had used to suffer with leaves in the scuttle box drain, leading to water in the blower connector..
I had the door card off at the week end and checked for damp in the switches and connections but all dry.....
I'll check the back window wiper next......
Is there any obvious earth connections I could check?
Thanks again..
Link to comment
Water ingress / damp is the likely cause for all your issues.
The strange dash light behaviour is regularly reported at this time of the year as the car interior gets colder and damper...
http://www.briskoda.net/forums/topic/383236-dim-dash-lights/?hl=%2Bdash+%2Blights#entry4488406
Although it can also be battery related...
http://www.briskoda.net/forums/topic/382290-dash-lights-flickering-video-uploaded-to-youtube/?hl=%2Bdash+%2Blights#entry4503640
The rear wiper is also moisture related, a lack of grease, poor quality motor and a design which sees the washer fluid fed through the motor means they fail regularly.
The electric windows are a little strange, there is clearly power getting to them.
Link to comment
Car has given me more clues::
Ok Replaced Battery --- No change----
Started pulling it to bits at tail gate end  all internals totally dry, wiper motor seal all good...
Then opened drivers window and it could not shut it even with the key which was working before.....
I pulled off the rubber gator which covers the wiring loom between the A pillar and the drivers door. The top plugged connection showed suspect oxidisation so WD40'd along with other two plugs, bottom end of loom where it enters the car door was wet. and showed minor signs of abrasion but not through the outer loom cover.
Again WD40'd it and found Door Controls for Drivers window now worked!!! although Back left window did not...
Also Rear window wiper now working
So Currently problems are
Dashboard
Electric Windows Drivers door controls works on 3 out of 4
Unless  anyone has any better ideas I'm thinking of replacing the Driver door wiring loom
all
Link to comment
  • 4 weeks later...
Carista diagnosis Fault highlighted in RED
Action Stripped out steering column module and checked circuit board for visible issues - none
Will now replace electrical part of Ignition switch
Problems still as above
Still waiting for correct drivers door wiring loom.
getting mighty hacked off!
ECU info obtained with Carista 2.6.1 for Android:
Engine
Part #: 03G906021LB
Component: R4 1,9L EDC 000
Coding: 71 (decimal)
Fault codes:
P161A Manufacturer-specific code
P161B Manufacturer-specific code
P161C Manufacturer-specific code
P161D Manufacturer-specific code
ABS
Part #: 1K0907379P
Component: ASR FRON
Coding: 17025 (decimal)
[No fault codes]
Steering angle
[failed to connect]
Power steering
Part #: 1K2909144M
Component: EPS_ZFLS Kl.068
Coding: [none]
Fault codes:
00778 Steering Angle Sensor (G85)
Airbags
Part #: 1K0909605T
Component: Q4 AIRBAG VW8
Coding: 20788 (decimal)
[No fault codes]
Instrument cluster
Part #: 1Z0920912D
Component: KOMBIINSTRUMENT
Coding: 3401 (decimal)
[No fault codes]
Immobilizer
Part #: 1Z0920912D
Component: IMMO
Coding: [none]
[No fault codes]
Central electronics
Part #: 3C0937049AH
Component: Bordnetz-SG
Coding: 00880F230004140000110D000000000000097B075C000000000000000000 (hex)
[No fault codes]
Body/convenience system
Part #: 1K0959433BT
Component: KSG PQ35 G2
Coding: 80801A085283007F3F04850540085F96907CA0 (hex)
[No fault codes]
Driver's door
Part #: 1T0959701D
Component: Tuer-SG
Coding: 756 (decimal)
[No fault codes]
Front passenger's door
Part #: 1T0959702D
Component: Tuer-SG
[No fault codes]
Rear left door
Part #: 1K0959703J
Component: Tuer-SG
Coding: 144 (decimal)
[No fault codes]
Rear right door
Part #: 1K0959704J
Component: Tuer-SG
[No fault codes]
Steering wheel
Part #: 1K0953549BC
Component: Lenksäulenmodul
Coding: 12 (decimal)
Fault codes:
00883 Ignition starter switch (clamp S)
Heater & air conditioning
Part #: 1Z0820047K
Component: Climatic PQ35
Coding: [none]
[No fault codes]
Radio
Part #: 1Z0035161C
Component: Radio FO3
Coding: 402 (decimal)
[No fault codes]
CAN network gateway
Part #: 1K0907530L
Component: J533 Gateway
Coding: E9807F060002022303 (hex)
[No fault codes]
Link to comment
Steering wheel
Part #: 1K0953549BC
Fault codes:
Fixed this by changing the electrical part of the ignition switch....However still have all the other problems, I seem to have cured the only problem that had no symptons...
waiting for door wiring loom...
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
