Replacing small control arm bush on 2008 fabia
fabia_fan
Recommended Posts
Hi  Has any member had experience in replacing the small rubber/metal pressed in bush on the front control arm (wishbone) I am replacing the console bushes  and thought I would also renew these bushes as well, I have gathered a lot of information on replacing the console bushes but can not find much on the the other bushes. Thank you
Link to comment
Share on other sites
You have posted this in the guides section. This is normally for guides showing you how to do something rather than requests
However once the wishbone is out you can push the front bush out. I usually use a big socket, threaded bar and a nut and washer.
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
